Old November 26th, 2011, 12:37 PM   #1 (permalink)
njdevilsfan427's Avatar
Vehicle: 06 Eclipse GT
njdevilsfan427 is on a distinguished road
how do we handle in the snow??
Hey guys, my 4g is my only car and winter is approching so I was wonderin if any of you drive your 4g in the winter and how it handles. I live in iowa so we see a fair amount of snow every year and I want to know if ill be able to get around without a problem. I'm stock so I'm not lowered or anything.
njdevilsfan427 is offline   Reply With Quote
Old November 26th, 2011, 12:56 PM   #2 (permalink)
The O.G.
horse-eater's Avatar
11 Highscores
Vehicle: 2006 eclipse GT-TT
horse-eater has a reputation beyond reputehorse-eater has a reputation beyond reputehorse-eater has a reputation beyond reputehorse-eater has a reputation beyond reputehorse-eater has a reputation beyond reputehorse-eater has a reputation beyond reputehorse-eater has a reputation beyond reputehorse-eater has a reputation beyond reputehorse-eater has a reputation beyond reputehorse-eater has a reputation beyond reputehorse-eater has a reputation beyond repute
Not terrible, but your gt has tons of torque so far in the rev range that it gets squirrley easy. But it isn't too bad, the biggest pain in winter driving is abs, sometimes you want wheel lock up to help dig down to solid dirt.
I do recommend getting some good all season or some winter tires.
Under construction! Converting to single turbo, more to come!
Twin Turbo- 338whp/311tq@4psi - Mustang dyno, courtesy PIA in Spanaway, WA.
Panty dropping ability courtesy Forward Motion, Road///RaceEngineering, BrianJ, Delta Cams, Custom Import Heads
horse-eater is offline   Reply With Quote
Old November 26th, 2011, 01:01 PM   #3 (permalink)
Daxenth's Avatar
Vehicle: 2008 Eclipse GS-N
Horse got it. i have the GS so all the weight, not the torque. i bite the road pretty good on all season, but there were times ive slid through stop signs or had to take the next street down cause when i cut the wheel, i just went straight lol. just keep your launches steady and give yourself plenty of time to slow down (more of a coasting than braking) and you should be good man
Mods=Daxenth's Satin Girl
Buy My Stock Shit!
Old November 26th, 2011, 01:55 PM   #4 (permalink)
gotJDM's Avatar
Vehicle: 2009 Eclipse GS
gotJDM is on a distinguished road
I have the GS and I'm on STOCK tires, stock height, etc. I did pretty well last year. Just keep your revs under control like everyone said; GTs really do have killer torque (try moving from second gear instead of first). DON'T SPEED and begin braking early (obv) because you will go straight like Jeff said, LOL. The ABS really is annoying. You'll definitely feel resistance when braking so BRAKE EARLY. Also, be careful of your front bumper; I still have dinges from last winter. -___-
6000K HIDs. Blue Interior Accent Lighting. Custom SRI. Ceramic Brakes. Tints. Smoked Tails. White Turn Signals. Resonator Delete. Tein S-Techs.
gotJDM is offline   Reply With Quote
Old November 26th, 2011, 05:01 PM   #5 (permalink)
choppertwo's Avatar
YEA thats about it, if the snows is heavy on the ground, start out in second gear and don't over do it, and go slow , you will be fine-- CHOP- 2 winters in the snow
Old November 30th, 2011, 02:09 PM   #6 (permalink)
hey thanks for the replies, my back tires dont have much tred on them so i should probably get those replaced before winter and i'll try to keep my launches under control.
Old November 30th, 2011, 02:55 PM   #7 (permalink)
pat_08GT_Spyder's Avatar
Vehicle: 08 GT Spyder 6MT
well, i'll add my 2 cents...
i have winter tires (Michelin PA3), more performance oriented than hardcore winter traction, but they do the trick... the Eclipse is a great car in the winter, warms up fast, behaves good with the right tires... start in 2nd to be safe, start in 1st and gun it with the TCL off for some fun
oh, and dont forget the e-brake if you get to an empty parking lot
depending where you are, you might get away with all-seasons... if winter is 6 months long like here, you might as well invest in a set of proper winter tires / rims.
Old November 30th, 2011, 08:26 PM   #8 (permalink)
Elitist Prick
Xero's Avatar
Vehicle: 2011/Eclipse GS
Xero is just really niceXero is just really niceXero is just really niceXero is just really nice
I get horrible understeer even on rainy days.
RRE UPD, Custom Exhaust, CAI, Megan Racing Springs, Ralco Short Shifter, Eibach Rear Sway, HID Projectors, LED Tails, AIC CF Hood, Vortex Generators, Rear Seat Delete, Grillecraft Grille, Big Cock
Xero is offline   Reply With Quote
Old November 30th, 2011, 08:30 PM   #9 (permalink)
on stock tires? my RS-A are useless when temps drops around 0 C...
Old November 30th, 2011, 08:41 PM   #10 (permalink)
nokiauser's Avatar
Vehicle: Eclipse GS 5 Speed
I've spent a few snowy Minnesota winters on lowering springs, cold air intake, and all seasons with no problems as a daily driver.
Best advice I can give you is to get decent tires and drive like you would drive any other car.
car, drive, handle, live, lowered, problem, stock, winter
