Old December 6th, 2011, 07:58 PM   #1 (permalink)
mayday295's Avatar
Vehicle: 2008/Eclipse/GT
mayday295 is on a distinguished road
Broken wheel stud
So my rear wheel stud has been broken, and I just saw Orangecrush's guide for replacing it, so i figured what the heck might as well. BUT the problem I have run into is after getting rotor and brakes off, as well as the four bolts on the back, I can't manage to get the brake assembly/hub off! I have pulled and pulled, and sprayed with pb blaster for a couple hours, and pulled some more but it won't budge!
Is it just that it is seized or is there a trick to this?
mayday295 is offline   Reply With Quote
Old December 6th, 2011, 08:35 PM   #2 (permalink)
OneStepBeyond's Avatar
Vehicle: 2008 Eclipse GS
OneStepBeyond is on a distinguished road
thats why i havent changed mine. been a while , think you need an air pressure wrench
OneStepBeyond is offline   Reply With Quote
Old December 6th, 2011, 09:53 PM   #3 (permalink)
mayday295's Avatar
Never mind i got it, PB blaster, 5 hours, many hits with a hammer, and a wedge later.... its off!
Old December 6th, 2011, 10:44 PM   #4 (permalink)
mayday295's Avatar
Actually, now my problem is after i get the assembly off, i cant figure out how to separate the hub wheel bearing part from the e brake assembly.
Anybody know how to get this apart? I read the post, where it says pry with your fingers, but I don't get what I am pulling off, nothing is coming off with my fingers very easily.
Old December 7th, 2011, 12:10 AM   #5 (permalink)
mayday295's Avatar
Also, now my parking break is making a lot of spring squeaks if I apply it, then try to rock the car back and forth (only sound coming from the one I just finished working with). Does that normally happen?
back, bolts, brakes, broken, problem, rear, rotor, wheel
