stalls without clutch when cold - Club4G Forum : Mitsubishi Eclipse 4G Forums - 2006-2012 Eclipse Authority
Old January 7th, 2017, 08:46 PM   #1 (permalink)
KuzuRyuSen is on a distinguished road
My 6 speed GT (which doesn't have a GT badge, and I don't know why but I want one, but that's for another thread) won't idle without the clutch pedal down. It turns over just fine, and it will run just fine as long as I sit there with the clutch to the floor, but if I put the stick in neutral and let the pedal out, it stalls out. It's a smooth stall, but a stall nonetheless. What this translates to is that I can't let my car run for a few minutes to warm up, along with the heater and the seat warmer, when it's cold out. I can't even let it run while I scrape the frost off the windows. By the time I get to work, it's fine and will idle properly. By then, however, it is too late
What's up with this? How do I make it not be that way?
KuzuRyuSen is offline   Reply With Quote Quick reply to this message
Old January 8th, 2017, 01:51 AM   #2 (permalink)
Super Moderator
Does the car need to be driven to not stall, or if you sat and actually held the clutch down until the engine was warm could you then put it in neutral
I'm not suggesting that for a practical "fix", it just helps with troubleshooting
Bad old thick oil doesn't like the cold, so I could see that slowing you down, Especially if water has seeped in over the years, which could freeze as well and compound the issue
Old January 9th, 2017, 07:55 AM   #3 (permalink)
I don't know about letting it sit long enough to be able to hold an idle, because I'm not that patient But presumably that would work because after it's been warmed up from driving it works just fine, and I'm sure the 'warmed up' part and not the 'driving' part that does that.
Old January 9th, 2017, 09:08 AM   #4 (permalink)
Super Moderator
Try just taking off in gear with it cold, then after a few yards put it in neutral and let off the clutch again. See if it still stalls
Old January 17th, 2017, 09:44 AM   #5 (permalink)
I tried this morning and was able to idle after moving it a bit, but it was also much warmer this morning, relatively, than when this is an issue. It may be that it just wasn't cold enough for the problem to surface, or it could be that the short distance means whatever you think it means and you have a correct idea of the problem.
6 speed, badge, car, clutch, cold, floor, idle, long, pedal, seat, speed, thread, work
Clutch and Transmission Noise Ohioguy Problem Reports 10 January 4th, 2017 12:14 PM
Desperate new own of a 4g need help clutch problem taweel26 Problem Reports 5 August 6th, 2016 01:05 PM
Question: DESPERATE FOR HELP NEW OWNER OF A 4g eclipse gt clutch stopped working taweel26 2006-2012 Eclipse (General 4G) 0 August 4th, 2016 11:55 PM
Aftermarket flywheel pilot bearing? Clutch issue inherheart Problem Reports 1 January 27th, 2016 04:34 PM
Question: Clutch problem Zachary17 Driveline 2 January 15th, 2015 08:30 PM
