#41 (permalink) | |
Reppin all Guyanese
2008 Eclipse GT-SE
Or is Mitsubishi just retarded, having the light come on for any stupid reason?
Fujita CAI, Magnaflow Catback Exhaust, Eibach Pro Kit Springs, 20% tint, Vision-style Eyelids, Custom-Painted front bumper, 6000K HIDs... |
| Club4G Sponsors |
#42 (permalink) |
vTak
2008 Eclipse GT
i looked through the book and the only thing i saw was something along the lines of please see your dealer but its safe to drive
where at in the book did you see it?
Fujita CAI | 3" Aeon Exhaust to HKS Axle Back | 6K HIDs | Tint | Vision Lids | Progress Rear Sway Bar | Tanabe Strut Bar National Mitsu Meet Here! |
#43 (permalink) |
06 Eclipse GT
I think most if not all the things that will set the TCL light have "something" to do with the TCL system. In other words, if you have a speed sensor go out, that could affect traction control...if an injector isn't working properly, that could affect it...any parameter the traction control routine would look at or use will turn that light on I believe.
MR. DSM...it's not just in one spot in the book...if you look at individual codes it will tell you what lights/codes will be set if the conditions are out of spec...there are several that say they'll set the TCL light. Brian
#44 (permalink) | |
Reppin all Guyanese
2008 Eclipse GT-SE
But rather the in-depth one that Russ has in his signature.
#45 (permalink) |
vTak
2008 Eclipse GT
would make more sense huh? exam week...im not all here haha
#46 (permalink) |
Reppin all Guyanese
2008 Eclipse GT-SE
lol...I know the feeling....or lack of.
#47 (permalink) |
Eddie
2006/Eclipse/GT
Hey people, add me to the list.lol. I just started getting these also. I have a k&n, headers, full exhaust, etc. I recently put O2 sensor spacers. Oh and the light comes on during highway driving.
#49 (permalink) |
The Dark Side
2006 Eclipse GT
My exam for Organic 2 ends at 4 so I'll be at AutoZone at 5......updates then!!!
2006 Kalapana Black Eclipse GT, Sportronic, Blackout Badge, Grill Delete, Ralliart Eyelids, No DRL, Injen CAI, 3" Header Back Exhaust with HKS tip, Momo Shift Knob and Pedals, H13/H11 8K HID, LED Interior Lights, 35% Tint, Dual Rockford Fosgate P1 In A Custom Sub Box/ T400-2 Amp...Soon Manual Cut Out and Painted Rims (Black) |
#50 (permalink) |
The Dark Side
2006 Eclipse GT
Code - P0171
Supposed to be something with a vaccum hose or the gas cap (not all the way closed) I taped the blue cylinder hose for the stock box vaccum. That seemed to stop everything but we will see.
#51 (permalink) |
vTak
2008 Eclipse GT
mine has yet to do it again and its been colder...maybe the ecu has adapted to it and alls good for now? we'll see
#52 (permalink) |
vTak
2008 Eclipse GT
sooo it did it again tonight on the way to cookout at 10:15 so i had nowhere to take it to scan...stupid yellow lights...stupid eclipse ecu
#53 (permalink) |
vTak
2008 Eclipse GT
bump yet again
came on tonight as i was passing advanced...but this time it came with the service engine soon light so i turned around and had it scanned P0714 which the guy told me was something to do with a lean bank but according to the thread on obdII codes here on c4g its "Transmission Fluid Temperature Sensor Circuit Intermittent" ideas? probably going to call mitsu and set up an appointment later this week if unhooking my ecu for a few doesnt fix it
Fujita CAI | 3" Aeon Exhaust to HKS Axle Back | 6K HIDs | Tint | Vision Lids | Progress Rear Sway Bar | Tanabe Strut Bar National Mitsu Meet Here! Last edited by Mr DSM; December 20th, 2009 at 06:09 PM. |
#54 (permalink) |
06 Eclipse GT
^^^ First time I'm seeing that one...best get it checked out...
#55 (permalink) |
Did u see GT on the back?
2006 Eclipse GS W26
Yeah thats deff a first lol
"Owning a 9 second neon is like comming out of the closet. At first you suprise everyone, but in the end your still gay." |
#56 (permalink) |
vTak
2008 Eclipse GT
service engine soon light cut off...now im light-less....damn ecu make up your freakin mind
#57 (permalink) |
The Dark Side
2006 Eclipse GT
If I drive in under 40 degrees the TCL lights come on and then will shut off with a restart. I think it's a Mitsu gimic to get all of us in the dealership.
#58 (permalink) |
2007 Eclipse GT
Happened to me today too. Mine is an 07 stock GT. The only thing I've done recently is change the oil. I checked to make sure filter is on tight, and oil level is ok. Nothing is leaking. Was driving it normally when the Traction Control and 'squiggly tires' lights came on. Temperature outside was 54F, its in FL, so my car doesn't experience low temps often. Been in the 40s all week. I'll take it by advanced to see if they can pull a code. Called stealership that I bought it from, they told me they've never seen that on the eclipse before and wanted to set up an appointment to bring it in. It's still under warranty, so I might just do that (23.5k miles since June of 2007).
#59 (permalink) |
vTak
2008 Eclipse GT
well this is good news actually
this means that its not due to mods so the dealer can fix it under warranty
#60 (permalink) |
2006 Mitsu Eclipse Gt
Well guys...add me to the list now....I was at a stop light and probably shouldnt have but did and gassed on it not really hard but harder than normal...when I hit 4,000 rpms around that time when MIVEC should do its thing car stated acting like MIVEC wasn't kicking in or something started acting like all the cylinders excpet for one was misfiring...looked at the gauges and there was our two little awesome lights TCL and mr. squiggly car. I've unplugged the battery, taken the ECU fuse out, reseated the MAF sensor plug, listened for any crazy vaccuum leaks...nothing. I turn the car back on after doing all of this...service engine is on...so thats a plus...but at first the two lights don't come on but the service light does immediately but after 20 secs of the car running the two infamous lights come on...so i'm not sure if its throwing a code.
When I was driving I tried again getting up to 4,000 rpms didn't happen...I think mitsu put in a safety feature that if those lights are one then it will not allow you to exceed 4,000 and overrides MIVEC "for your safety"...well what about the safety of my mental well being from being so frustrated with this $h!t...GAH..... any other brainstorming? I'm going to Checkers tomorrow ASAP to check for a code...hopefully I'll have one... I have installed a Fujita CIA and i've had a code since that...could never get rid of it. I think it was the P0171 code...so if anything's different than that I'll assume its from this TCL and mr. squiggly getting involved.
Dream as if you'll live forever. Live as if you'll die today. http://i186.photobucket.com/albums/x...1/102_0472.jpg |
| Club4G Sponsors |
