Blowing hot air - Club4G Forum : Mitsubishi Eclipse 4G Forums - 2006-2012 Eclipse Authority
Old April 14th, 2010, 01:25 AM   #1 (permalink)
Vehicle: 2006 GS
AED55 is on a distinguished road
Blowing hot air
There are times when the weather is a little too cool for A/C, and I just want some cool outside air to flow from the upper vents. When I turn the temp knob to the cool side and set the other control to blow from the upper vents, I get warm air, no matter what the outside temp is. I've even tried running the A/C for a while to cool the ducting down, but when I turn the A/C off, in a few minutes I get warm air from the vents again. Just wondered if this might be something simple to fix, or should I bite the bullet and take it to the stealership.
AED55 is offline   Reply With Quote Quick reply to this message
Old April 14th, 2010, 10:41 AM   #2 (permalink)
Lathe Master
Ricoswave's Avatar
Vehicle: 05 Lancer Evolution
All of these cars do that. Call it a design flaw. A real annoying one too.
Mods:
Ricoswave is offline   Reply With Quote Quick reply to this message
Old April 15th, 2010, 07:17 PM   #3 (permalink)
Vehicle: 2008 eclipse spyder gs
sk13322 has a spectacular aura about
yeah its heat from the motor
VIS carbon fiber hood, hood pins, DRL MOD, fujita CAI, 3A racing muffler, Factory wing, Rockford upgraded door speakers, GPS, slottled and crossed drilled zinc roters with cermaic pads, RRE UDP, Oil cap.
sk13322 is offline   Reply With Quote Quick reply to this message
Old April 15th, 2010, 09:04 PM   #4 (permalink)
mild fanatic
Vehicle: 06 Eclipse GT
rex696 is on a distinguished road
try pushing the recirc button and see if that helps you any. ive found it helps with the hot air that naturally comes through even when the blower is off
rex696 is offline   Reply With Quote Quick reply to this message
Old April 15th, 2010, 11:14 PM   #5 (permalink)
Vehicle: 2006 GS
Thanks for the suggestion, I'll give that a try. I also noticed that the A/C doesn't seem to be as cold as it should be. Makes sense since it's having to compete with the warm air that's always circulating in the ducting.
Seems like something like this should be a no brainer for an auto engineer. Let's see, we'll run the A/C ducts close to a hot engine, that shouldn't be a problem. Maybe they hired the guy from Toyota.
Old April 15th, 2010, 11:19 PM   #6 (permalink)
jvu
Cocknozzle
Vehicle: 2009/Eclipse/GT-P
jvu is just really nicejvu is just really nicejvu is just really nice
if yoru ac isn't cooling up as quick, maybe its not charged. pick up a can and charge it up.
jvu is offline   Reply With Quote Quick reply to this message
Old April 16th, 2010, 01:05 PM   #7 (permalink)
Vehicle: 2006 GS
I think the A/C is working OK because if I turn it on when the engine is cold, it blows plenty of cold air, and then gradually gets warmer, as the engine warms up.
Does anyone know if there was a TSB issued for this problem?
Old April 16th, 2010, 04:11 PM   #8 (permalink)
got a quote
RJ88's Avatar
Vehicle: 2009 Eclipse GS
RJ88 is a splendid one to beholdRJ88 is a splendid one to beholdRJ88 is a splendid one to beholdRJ88 is a splendid one to beholdRJ88 is a splendid one to beholdRJ88 is a splendid one to behold
turn it all the way to max a/c. in my car, it wasnt hot anymore.
Nexus S 4G and Evo 4G for trade
RJ88 is offline   Reply With Quote Quick reply to this message
a/c, air, bullet, fix, vents
