Transmission Issues (limp mode? sensor? random thing?) - Club4G Forum : Mitsubishi Eclipse 4G Forums - 2006-2012 Eclipse Authority
Old September 3rd, 2015, 03:29 PM   #1 (permalink)
Vehicle: 2006 / GT / Sport
Xerin is on a distinguished road
Hi all,
I have a 2006 GT. I was pulling out from a red light (on a steep hill) when I noticed the car wasn't shifting, so I pulled off to the side of the road and put it in neutral and back into drive and nothing occurred. I then put the car into park, turned it off, cranked it back on, and then the transmission was totally fine, shifting as smooth as ever.
However, the display no longer showed drive but instead it simply showed the gears and showed it shifting through them. It would start at 1st, shift quickly to 2nd, then 3rd. If I accelerated it then shifted to 4th for awhile and then 5th. When I stopped, it'd shift down into 3rd, then down into 1st. I was able to get home without any issue.
When I shift in reverse, the car normally jumps a bit, but I was told that was the motor mount. When I got home, I put it into reverse and it jumped what felt like a bit more, but I was also having a panic attack. I went and shifted it around again recently and it seems fine.
I went and let it cool down, it shifts back into drive, but then randomly switched over into sport mode. It feels almost as if the transmissions flips over to sport mode for some reason. It can go up to 5th gear and I don't feel any weirdness in shifting outside of the one time it felt like it wouldn't shift up for some reason at the start of this.
I guess my question is, is there any harm in driving it? I'm thinking it's probably something that could be fixed by removing the battery for a bit, but I also don't want to cause more issues. There is no check engine light and nothing displayed on the radio display.
I tried searching for the answer, but all I found was limp mode, but limp mode seems to stay in 3rd gear. The car is shifting gears just fine. I checked the fluid while the engine was hot (ow ow ow), and it was near the line, with a smear running from the line down a little bit.
Xerin is offline   Reply With Quote Quick reply to this message
Old September 4th, 2015, 08:32 AM   #2 (permalink)
I called dealerships who said if it's shifting it's shifting. I drove it this morning and could shift manually if it got stuck in sport mode. I cut the lights off and automatic started working perfectly so I assume this is some really weird electronic glitch if the lights can put the car in sport mode. Any clue where to start? Literally if I cut the lights off it shows drive and shifts like normal. If I cut them off it shows the gear and will shift sometimes or sometimes act like it's in sport mode.
Old September 5th, 2015, 01:02 AM   #3 (permalink)
I have some good news and some bad news for you. The good news, this is a first for the sportronic transmission. The bad news it needs to be fixed before it gets worse.
Limp Mode. When our car goes into limp mode, it normally means there is something wrong with the engine, or one of the engine sensors. Limp mode is designed to prevent further major damage happening to the engine, but also gives you the ability to drive your car to a service station. However this is not the problem you are having.
Not all Codes/DTC will cause the Check Engine Light (SES) to come on. So you need to have your OBDII read for any Codes/DTC. If you have any codes, please right them down and post them online for us to see. Without any codes it will make t-shooting this problem more complicated.
I'll have to do some reading on this problem, so here is the Link to the Eclipse Factory Service Manual if you wish to help.
2006 Eclipse Factory Service Manual | Tearstone
GROUP 23A AUTOMATIC TRANSAXLE
http://tearstone.com/eclipsefsm/2006...004100-23A.pdf
GROUP 23C AUTOMATIC TRANSAXLE OVERHAUL F5A5A>
http://tearstone.com/eclipsefsm/2006...004300-23C.pdf
I'm not finding anything in the manual about this type problem. If you don't have any codes/DTC you might be looking at a wiring problem (SWS).
Old September 5th, 2015, 07:30 PM   #4 (permalink)
Thanks! I'll get the codes pulled tomorrow. I drove it a small amount and as long as the lights are off, there is literally nothing wrong with the car. When the lights come on, Drive shows the gear its in, and it might sometimes kick into sport mode (manual shifting) but cutting the lights off makes it work just fine.
Really, really weird.
Old September 6th, 2015, 04:38 AM   #5 (permalink)
This is beginning to look more like and electrical problem. We'll see...
Old September 10th, 2015, 02:12 PM   #6 (permalink)
Pulled the codes at two different locations, showed nothing. Car runs amazingly fine with the lights off. If you cut them on, after a random time, D will turn into the gear that it's currently in. From there, it could randomly decide it's in sport mode and you have to shift it manually. Turning the lights off instantly returns the car to it's perfect point.
Where would the light switch / lights meet the transmission?
Old September 10th, 2015, 02:54 PM   #7 (permalink)
We have several on-board computers on our car. These computers monitors system equipment by resistance and can/will shut down systems if it feels there is something wrong with that system/equipment.
The first thing we need to know if you taped into any wire/s or electrical harness/es. I.E. If you taped into a wire for a aftermarket stereo, LED Lighting, hard wiring a GPS, radar detector, added any aftermarket headlights, or taillight. Did you do any work electrical or otherwise under the dash, or engine bay. Maybe some cleaning around the steering wheel, or gearshift. Dropped something in or around the gearshift or steering wheel. Anything electrical??
There are a couple switches inside the gear lever selector (Gearshift). If, if any of those switches are bad, not saying they are, there are no replaceable parts in the gearshift, so the whole shift lever assembly will have to be replaced... around $500.
I've seen were people have tried to dust between the steering wheel column and the steering wheel, and ruin the clock spring assembly. Or your clock spring assembly might have gone bad.
I'm just trying to throw some things out there that might have caused this problem to help t-shoot this problem. But this is beginning to sound more electrical then a mechanical problem with the transmission, or cable problem.
Could even be a broken ground wire, or where you added a ground wire for a modification??
Just to give you an idea how particular our electrical system is... If you install aftermarket tail lights without adding a load resistor, any or all the following might happen; interior lights will stop working, cruse control will stop working, and/or certain dash lights will stop working. So what would the taillights and cruse control have in common you might ask... The ECU that controls and monitors those systems/equipment. The ECU sees a resistance change and acts accordingly. It sees a resistance change in the taillights and starts to shut-down other systems to protect them, before even blowing a fuse.
Old September 10th, 2015, 03:26 PM   #8 (permalink)
There are only a few small modifications to the vehicle. Four years ago, I had an antenna pass-through installed for an AUX port that's under the arm rest. You know the one that connects to the incoming antenna and you flip a switch between aux / FM. Three years ago I had the negative battery terminal replaced, it's properly grounded and installed, and on tight and a new condenser installed. I was rear-ended and had a new rear bumper installed. About a month and a half ago I installed a new headlight, using the standard one that goes into the car, along with two new front tires and an oil change.
Beyond that, I don't think I've spilled anything super recently into the gearshift. I might have spilled something at some point, but I wouldn't remember it.
I'd like to try to figure out a reasonable way to figure out what's wrong, because I don't want to play let's replace a billion parts with a mechanic, especially with something as random as "turn the lights on and your car might got into sport mode." Windshield wipers don't do it, only the lights. One odd thing about the lights, which I thought was normal, is if I have ever turned them on, the gear display turns really dim, while the rest of the dash brightens up. I figured that was on purpose, though.
Old September 10th, 2015, 03:56 PM   #9 (permalink)
GROUP 54A CHASSIS ELECTRICAL
http://tearstone.com/eclipsefsm/2006...002100-54A.pdf
COLUMN SWITCH REMOVAL AND INSTALLATION PAGE 54A-149
ETACS-ECU REMOVAL AND INSTALLATION PAGE 54A-51
COMBINATION METER ASSEMBLY PAGE 54A-52
GROUP 54B SIMPLIFIED WIRING SYSTEM (SWS)
http://tearstone.com/eclipsefsm/2006...002200-54B.pdf
GROUP 54C CONTROLLER AREA NETWORK (CAN)
http://tearstone.com/eclipsefsm/2006...002300-54C.pdf
GROUP 80A CONFIGURATION DIAGRAMS
http://tearstone.com/eclipsefsm/2006...000200-80A.pdf
GROUP 80B SPLICE LOCATIONS
http://tearstone.com/eclipsefsm/2006...000300-80B.pdf
GROUP 90 CIRCUIT DIAGRAMS
http://tearstone.com/eclipsefsm/2006...0000400-90.pdf
HEADLIGHT . . . . . . . . . . . . . . . . . . . . 90-106
CONTROLLER AREA NETWORK (CAN) 3.8L ENGINE-A/T> . . . . . . . . 90-408
METER AND GAUGE A/T> . . . . . . . 90-154
06 gt, 2006, art, back, battery, car, display, drive, engine, fluid, hot, issue, issues, king, light, motor, mount, question, random, red, road, sensor, sportronic, start, transmission
Standard transmission issues 07-eclipse-newbie Other cars 8 August 24th, 2015 11:07 AM
Limp mode symptoms? Clovisman!! #MitsuGang Problem Reports 5 August 2nd, 2015 08:07 AM
06 Eclipse GT - TPS Code - Stuck in LImp Mode 4g216 Problem Reports 7 July 25th, 2015 04:53 PM
