How To Guide Remove Dash Panel - Club4G Forum : Mitsubishi Eclipse 4G Forums - 2006-2012 Eclipse Authority
Go Back   Club4G Forum : Mitsubishi Eclipse 4G Forums - 2006-2012 Eclipse Authority > Performance and Technical > Do It Yourself Guides (Howto) > Show Tech
Old July 17th, 2012, 04:20 PM   #1 (permalink)
Mr. Offensive
Phantom_4G's Avatar
1 Highscore
Vehicle: 2006/Eclipse/GT
Phantom_4G has a brilliant futurePhantom_4G has a brilliant futurePhantom_4G has a brilliant futurePhantom_4G has a brilliant futurePhantom_4G has a brilliant futurePhantom_4G has a brilliant futurePhantom_4G has a brilliant futurePhantom_4G has a brilliant futurePhantom_4G has a brilliant futurePhantom_4G has a brilliant futurePhantom_4G has a brilliant future
Remove Dash Panel
I Did not completely remove mine for this how-to, but hopefully my pictures will be sufficient in helping you understand how this is performed.
Total time: 15-20 mins
Difficulty: 3/10 Its alot more simple once you understand how it is in place.
Purpose for removing: Painting or replacing
Tools Needed: 1 phillips Screwdriver,1 flathead screwdriver or pry bars, 3m heavy duty Double-sided tape or gorilla glue
STEP 1: Radio face plate by pulling it straight towards you
STEP 2: Remove Speedometer Cluster by completely lowering your steering wheel, pulling cluster straight towards you, then disconnecting the clip for the cluster
STEP 3: (not pictured) Remove the 2 vent covers
STEP 4: Pull down on this plastic piece circled
STEP 5: Open glove box and unscrew the 2 circled screws with phillips screw driver and pull down on that plastic bar the screws held up
STEP 6: Proceed to remove the dash panel.
You can start from left to right, top to bottom, or vice versa. This is what you are dealing with under the actual panel
You can see that the panel has its own platform that is seperated and a completely different material from the actual dash itself. Notice that as you pull up on the top portion of the dashpanel and uncover an excess flap thats about an inch long that outlines the top of the panel. this excess needs to be tucked back in between the panel platform and the actual dash when you go to re-install
Now focus your attention to the circle tab to the immediate left of the vent. These are spread out across the platform and these are the only thing securing the panel to the platform other than the 2 dash pieces that you already pulled down. I'll give you a closer look.
This is that circle tab i talked about earlier. its actually a small circular indent in the platform itself
This is what goes into that indent and is what adheres the panel to the platform. When prying the panel away from the platform, be careful not to rip these off. They come will tear if you pull straight up instead of prying as you pull
When you go to replace it. I strongly recommend you start with the top.
I started with the bottom. I secured the tabs tightly in place, used cheap double sided tape for it to stick to the platform, then rolled the top excess flap in place and called it done.
In 100+ degree temperature.. the double sided tape lost its adhesion abilities on the backside of the dash panel and peeled up. And those bottom tabs that i tightly secured... they were pulling the panel down making it difficult for the top excess flap to stay in place, so the end result looked like this.
So to eliminate this..secure the top first. This time around I used 3m tape and velcro so i can take off and replace as needed. If this doesnt work... I will resort to glue which will be a pretty permanent solution.
Once the top is secured, you can replace those bottom plastic panels to secure the bottom flaps of the panels, then replace the screws, cluster, vent covers, and radio face plate.
This was just a quick down and dirty. Next time i completely remove it, I will take better pictures to give you the full effect of it being completely off and of the re-installation
Thanks for viewing. any questions? Post them here.
Follow the official Club4G Instagram at @club4g
Phantom_4G is offline   Reply With Quote Quick reply to this message
Old July 17th, 2012, 04:32 PM   #2 (permalink)
UV Blue Crew
jhun35's Avatar
Vehicle: 2006 Honda Civic Si
jhun35 is a splendid one to beholdjhun35 is a splendid one to beholdjhun35 is a splendid one to beholdjhun35 is a splendid one to beholdjhun35 is a splendid one to beholdjhun35 is a splendid one to beholdjhun35 is a splendid one to behold
nice write up man. I've wanted something like this for awhile.
jhun35 is offline   Reply With Quote Quick reply to this message
Old July 17th, 2012, 04:35 PM   #3 (permalink)
-cruzer-
JoeyC's Avatar
Vehicle: 2006 ECLIPSE GT
JoeyC is a name known to allJoeyC is a name known to allJoeyC is a name known to allJoeyC is a name known to allJoeyC is a name known to all
E-rep++
JoeyC is offline   Reply With Quote Quick reply to this message
Old July 17th, 2012, 05:02 PM   #4 (permalink)
Real men have a STICK!
ChrisB's Avatar
Vehicle: '08 Evo X GSR
ChrisB is a name known to allChrisB is a name known to allChrisB is a name known to allChrisB is a name known to allChrisB is a name known to all
+ E-rep
Thank you Sir!
ChrisB is offline   Reply With Quote Quick reply to this message
Old July 18th, 2012, 12:32 PM   #5 (permalink)
REDLINE
Boatright's Avatar
1 Highscore
Boatright is a glorious beacon of lightBoatright is a glorious beacon of lightBoatright is a glorious beacon of lightBoatright is a glorious beacon of light
Thanks man, really helps out.
OBX longtubes, SRI, Helix TB spacer, Stiffy, Flowmaster, RL Cutout,
EVO wing, halo fogs, black projectors, Konig sideways, 09 front end swap, Kicker SS.
Boatright is offline   Reply With Quote Quick reply to this message
Old September 14th, 2012, 02:35 PM   #6 (permalink)
Mr. Offensive
Phantom_4G's Avatar
1 Highscore
For paint.. i used duplcolor grey primer, and rustoluem blue vinyl paint. i higly recommend you go with duplicolor vinyl paint
Old November 29th, 2012, 09:01 PM   #7 (permalink)
Cruvolo93's Avatar
Vehicle: 2009/Eclipse/GS
Cruvolo93 is on a distinguished road
So when you pull the speedometer cluster out can, can I remove the tpms system light bulb through that?
_Raviolli
Cruvolo93 is offline   Reply With Quote Quick reply to this message
Old November 29th, 2012, 10:15 PM   #8 (permalink)
Mr. Offensive
Phantom_4G's Avatar
1 Highscore
I never got that crazy far into the breakdown process but my guess is no? just a guess though
Old November 30th, 2012, 01:00 AM   #9 (permalink)
stumpy's Avatar
Vehicle: f
stumpy has a spectacular aura about
Maybe is my yr model but to get my gauge cluster out to paint it. I had 2 Phillips screws behind the rubber flap thats in between the gauge and steering.
stumpy is offline   Reply With Quote Quick reply to this message
Old November 30th, 2012, 01:17 AM   #10 (permalink)
dshaff3's Avatar
Vehicle: 2006 Eclipse GT/SE
dshaff3 is on a distinguished road
yeah i was trying to remove mine by just pulling it and nope that would not work.
i didn't want to pull too hard and break something.
ill look for the two screws
dshaff3 is offline   Reply With Quote Quick reply to this message
Old August 12th, 2014, 02:55 PM   #11 (permalink)
Vehicle: 2009 Eclipse GS
ShipyardWelder is a jewel in the roughShipyardWelder is a jewel in the rough
can you pull the dash and still put the cluster back in say if i needed to drive it to work but didnt finish my heater core install?
ShipyardWelder is offline   Reply With Quote Quick reply to this message
Old August 25th, 2016, 04:00 PM   #12 (permalink)
0 - 60 Eventually
Desert Rat's Avatar
Vehicle: 06 GT Manual
Bumping to add some info for future readers:
Indeed there are two screws that hold in the gauge cluster, here are some photos (rubber flap circled in red):
The entire dash, including the cluster, can be put back together when the vinyl piece is completely removed. Every piece aside from the vinyl are held in by screws and/or clips and the vinyl is purely decorative.
Desert Rat is online now   Reply With Quote Quick reply to this message
abs, back, box, car, dash, dent, head, how to, install, installation, long, lowering, painting, pictures, plate, questions, radio, remove, rip, speedometer, straight, temperature, top, wheel, work
Wtf?? How do remove dash speaker grills??!! deltaco4life Audio & Lighting 6 June 10th, 2015 01:15 AM
how do i remove the dash Red07Eclipse Interior and Exterior Modifications (Show) 1 November 21st, 2011 04:36 PM
Rubber dash panel behind steering wheel Lvcien Problem Reports 3 October 10th, 2011 09:01 AM
What is the difference between the metre dash kit and sscosche dash kit? marksmitsu219 Audio & Lighting 0 July 25th, 2009 05:49 PM
door panel's. grievence Interior and Exterior Modifications (Show) 3 June 17th, 2009 08:30 PM
