How To Guide Remove Trunk interior - Club4G Forum : Mitsubishi Eclipse 4G Forums - 2006-2012 Eclipse Authority
Go Back   Club4G Forum : Mitsubishi Eclipse 4G Forums - 2006-2012 Eclipse Authority > Performance and Technical > Do It Yourself Guides (Howto) > Show Tech
Old June 27th, 2007, 10:23 AM   #1 (permalink)
IH8Civix
Bart-man's Avatar
Vehicle: 06 Audi A4 2.0T
Bart-man has much to be proud ofBart-man has much to be proud ofBart-man has much to be proud ofBart-man has much to be proud ofBart-man has much to be proud ofBart-man has much to be proud ofBart-man has much to be proud ofBart-man has much to be proud ofBart-man has much to be proud ofBart-man has much to be proud of
*Original Post by Drew*
Well this all took me about two and a half hours. With my write-up and the pictures. It shouldn’t take you more than one and a half, even less. First panel I removed had me very dissolution as I broke a piece of the rear end trim. I wasn’t quite sure how to read the clip diagram, but the bit was easily JB welded on again, so all’s good. If you have the service manual you want to refer to Section 52A page 31. I’ll talk those of you that don’t through it, so you don’t really need it.
STEP 1: Remove your, cargo net, spare wheel cover, jack, spare wheel and tools.
STEP 2: _Removal of part #9 The Rear End Trim, that’s the 2 or so sq/ft piece of plastic at the very back end of your car. It has an insert in it that let’s you access the truck release manually. Remember this is your first step and from this you will learn the force requires to pop the clips. The piece has 4 clips on top, parallel to the ground, so you have to pop them up, towards the sky. This is the trickiest part of it all, honest. 2 clips are located in the first quarter of the panel. See pic below. What you want to do is carefully wedge a mid sized flat screwdriver at about 1 inches from the edge of the panel on either side. Push it in far enough that you clear the metal and have some leverage, you’ll know what I mean, then wedge up. You’ll hear a click-pop, STOP, don’t go any further. Next move to about 5 inches from the side on either side and do the same. Lift up slightly and tilt back. And you first panel is removed.
For a Hi Res image click here.
STEP 3: Remove TOP luggage hook part #10. Make sure you only remove the top one, the lower one is screwed on to the panel and not to the chassis. The luggage hook looks like a T shaped hook. This is where your cargo net attaches to if you have one.
STEP 4: For now you are going to be working with the passenger side, although everything reflects to the drivers side, but you may have a speaker to worry about, more on that later. Remove the Light Lens part #11. I used a flat head screw drive. It feels like it’s going to crack the lens, but just use slow gentle force till it pops off.
STEP 5: Unscrew the 2 screws that hold in the light and unplug the plug.
STEP 6: Both rear side panels have 7 screws, make sure you count them. One of them is easily overlooked. Once those are gone, there is just one clip, in abouy 5 inches and down 3. Just tug. Don’t worry about the safety restraint bolts close to the tail lights, you’ll clear them..
2006 Audi A4 quattro.
Bart-man is offline   Reply With Quote Quick reply to this message
Old June 27th, 2007, 10:25 AM   #2 (permalink)
IH8Civix
Bart-man's Avatar
That leaves you with this.
STEP 7: I thought it was about time to take out the back seat. So first the lower part, you know the butt cushion. Easiest part of it all. Just tug up at about 8 inches on either side. There are only two clip. You’ll have to feed the seat belt latches through the opening. And out comes the cushion.
STEP 8: Rear seat back support. Almost as easy. A bolt and a nut on either side and out they come.
STEP 9: Assuming you have one. Next step is the sub. Three 10mm bolts, a nut and a plug.
STEP 10: Remove the sub. Base bracket. 3 bolts. I marked around them to make sure I don’t place more than one layer of material underneath it.
STEP 11: Front scuff plate. You could have started with the next steps first, either way. This is part #1. It’s the piece of plastic between your seat and scuff plate that says ECLIPSE on it on both the driver and passenger side. It’s got three clips and clamps. The clamps hold the molding (rubber seal). If it seems like it doesn’t want to come loose and is pulling up your weather stripping seal, just gently make up and down motions with the scuff while pulling down on the seal.
STEP 12: Hind quarter side trim, part #14. These are the large panels that are in front of the rear side speakers. You just have one screw to worry about, it’s at the very lower front of the panel. The panel has 6 clips, all about 2 – 3 inches from the sides. Start at the bottom, gently tug. It’s easy. To get the panel out you do have to unscrew the lower rear seat belt bolts and clip the seatbelt slot trim.
Old June 27th, 2007, 10:37 AM   #3 (permalink)
IH8Civix
Bart-man's Avatar
STEP 13: Unscrew the rear speaker cabins and unplug the speaker. Think it was 5 screws. Also noticed that the actual speaker screws that screw into the cabin, or housing, weren’t all that tight. Could explain some of the rattling. There is a seal between the speaker housing and the sheet metal, so tug gently Notice the 4 ohm 25W RF speakers. Pretty generic looking, but RF none the less.
Here is some foam sound proofing they stuck down in there, I plan to try and find some more tomorrow and do a better job.
Old June 27th, 2007, 10:38 AM   #4 (permalink)
IH8Civix
Bart-man's Avatar
That left me with this.
Donno what these vents are about. You can see sunlight on a sunny day if you fold back the rubber. I guess so that your neighbors can hear your bass.
That leaves me with these parts that hopefully I can put back in tomorrow,
Hope this helps someone.
Old June 27th, 2007, 12:20 PM   #5 (permalink)
The dick of JUSTICE
psy-q's Avatar
Vehicle: 2005 Galant ES
Those little vents in the back behind the panels are to equalize the pressure inside the car with the outside. That way when you close your doors you don't blow out the windows
You'll hear them flip open for a second when you close a door.
psy-q is offline   Reply With Quote Quick reply to this message
Old March 21st, 2008, 04:28 PM   #6 (permalink)
Robgee is an unknown quantity at this point
Any1 got the pix for this thread? Cuz id really like to know how to remove all that trunk stuff.
RobGee - 2006 Liquid Silver GT - 10k HID's and eye lids.
Robgee is offline   Reply With Quote Quick reply to this message
Old March 21st, 2008, 04:39 PM   #7 (permalink)
Still Salty
That_One_Guy's Avatar
Vehicle: 2015 Focus ST
That_One_Guy is a splendid one to beholdThat_One_Guy is a splendid one to beholdThat_One_Guy is a splendid one to beholdThat_One_Guy is a splendid one to beholdThat_One_Guy is a splendid one to beholdThat_One_Guy is a splendid one to behold
84' olds \
Sleep sweetly, noble steed.
You will be missed
That_One_Guy is offline   Reply With Quote Quick reply to this message
Old March 21st, 2008, 04:43 PM   #8 (permalink)
Mauricio is a jewel in the roughMauricio is a jewel in the rough
lol
BREAK YOURSELF FOOL!!!
Mauricio is offline   Reply With Quote Quick reply to this message
Old May 15th, 2008, 10:48 PM   #9 (permalink)
Bump Some MOre .!.
Old May 15th, 2008, 11:16 PM   #10 (permalink)
The Dark Side
Vader6's Avatar
Vader6 has a reputation beyond reputeVader6 has a reputation beyond reputeVader6 has a reputation beyond reputeVader6 has a reputation beyond reputeVader6 has a reputation beyond reputeVader6 has a reputation beyond reputeVader6 has a reputation beyond reputeVader6 has a reputation beyond reputeVader6 has a reputation beyond reputeVader6 has a reputation beyond reputeVader6 has a reputation beyond repute
Yea the link is wrong
2006 Kalapana Black Eclipse GT, Sportronic, Blackout Badge, Grill Delete, Ralliart Eyelids, No DRL, 3" Header Back Exhaust Dump off the Rear Axle, Momo Shift Knob and Pedals, H13/H11 8K HID, LED Interior Lights, 35% Tint, Dual Rockford Fosgate P1 In A Custom Sub Box/ T400-2 Amp...Coming Soon: Painted Rims (Black)
Vader6 is offline   Reply With Quote Quick reply to this message
Old May 19th, 2008, 02:59 PM   #11 (permalink)
Darkness's Avatar
Vehicle: 07 Eclipse GS
Darkness is a splendid one to beholdDarkness is a splendid one to beholdDarkness is a splendid one to beholdDarkness is a splendid one to beholdDarkness is a splendid one to beholdDarkness is a splendid one to beholdDarkness is a splendid one to beholdDarkness is a splendid one to behold
07 Kalapan Black GS
Darkness is offline   Reply With Quote Quick reply to this message
Old May 20th, 2008, 06:16 AM   #12 (permalink)
Iceman II's Avatar
Vehicle: 06 GT
Iceman II is a jewel in the roughIceman II is a jewel in the rough
ok here u go...i did this a while back..
finished with custom wrapped leather.
eibach, tints, chrome wheels, nitto 555, custom paint, custom seat backs, custom deck lid, footwell lighting, custom cargo area, Buschur CAI, AXB, RRE headers, Rosco custom shift knob, Akebono friction, DDM HID's.
Iceman II is offline   Reply With Quote Quick reply to this message
Old May 20th, 2008, 06:22 AM   #13 (permalink)
Iceman II's Avatar
Vehicle: 06 GT
Tru that...but when u park for winter like me u get mice inside eating ur shit..
i removed that flap casue the bass rattles it...sounded ghetto
and blocked it off. The windows drop down just before closign the door thats enough to bal pressure.
Old August 15th, 2012, 02:58 PM   #14 (permalink)
jmk167's Avatar
Vehicle: 2006 gs
jmk167 is on a distinguished road
wait there are supposed to be plastic panels back there all i have is metal and a spare-tire
jmk167 is offline   Reply With Quote Quick reply to this message
Old December 13th, 2012, 01:51 PM   #15 (permalink)
lf2074's Avatar
Vehicle: 2012 Eclipse SE
lf2074 will become famous soon enough
U need get these pictures fixed up again
Mods : Fujita F5 CAI, Dual Magnaflow Race Series Axle-backs, RRE UDP, BC Racing Coilovers, Carbing tower struts, RRE Headers w/ Jet Hot coating, Evo9 Brembos, Girodisc 2-piece floating rotors, Stoptech SS brake lines, Volk Racing Progressiv ME 19s, Nitto Motivo 235/35/19 fronts 255/35/19 rears, Blue dome light, Blue LED footwell lighting, Vis eye lids.
My Member's Ride Thread
lf2074 is offline   Reply With Quote Quick reply to this message
Old February 14th, 2017, 05:19 PM   #16 (permalink)
escapefate's Avatar
escapefate will become famous soon enough
pics dead
Sun and Sound Package.
escapefate is offline   Reply With Quote Quick reply to this message
Old February 14th, 2017, 05:41 PM   #17 (permalink)
DR3
DR3's Avatar
Vehicle: 07 Eclipse SE (GS)
DR3 has a spectacular aura about
https://youtu.be/9wBVVAgj4sA
That's the gist of it
DR3 is offline   Reply With Quote Quick reply to this message
back, bolts, clips, club, cover, drivers, flat, g/s, good, head, how to, interior, lights, lower, manual, original, pictures, rear, removal, remove, rim, service, tail lights, top, wheel
How to: Remove Headlights gc33550 Electronics 6 August 14th, 2015 08:45 PM
WTB: interiot trunk piece to hook trunk cover tamarockstarboi Automotive For Sale/Wanted 1 September 4th, 2012 05:54 AM
How To: Remove Grille 09+ Stefanos Show Tech 9 August 20th, 2012 07:44 PM
Remove Plasti Dip gotJDM Problem Reports 17 July 25th, 2012 03:03 PM
how do i remove the dash Red07Eclipse Interior and Exterior Modifications (Show) 1 November 21st, 2011 04:36 PM
