I need assistance installing some parts that may be a little out of my noobie league. Anyone, in/around new orleans, that can help let me know. also, if you know of any shops around my area that does aftermarket work please give me the info.
stuff i need help with:
manifold spacer
spark plugs
brembo rebuild (will attempt myself, thanks to the how to)
coilover and econ
Haven't done the manifold spacer but there's a writeup somewhere and it doesn't sound too difficult.
Spark plugs are easy as sin. Just ask and I can walk you through it...
Can't help you on the brembo's as I have no experience with those.
We've installed springs on Lisa's car and to my knowledge it's pretty similar except instead of placing springs around the struts and reinstalling you just remove and replace the entire thing. Again I can walk you through it if need be. Just send a PM.
your right, seems easy, but im under the impression any slight mistake can be fatal. is this so? if not i dont mind getting my hands dirty and giving it a shot, im just concerned with doing unrepairable damage to the engine.
same as previous, im told any mistake could be very bad. for instance, if they arent all screwed in to the same length...i dont have much mechanical experience.
thats comforting. i replaced the springs myself, so i think i can handle that part. heard anything about the econ install? where do people mount that? im considering putting it where the ralliart gauges are. have a housing made out of fiberglass, paint it silver, and hopefully itll look factory-ish. i have a double din so thats the only place i can think of putting it.
Related Threads
Mitsubishi Eclipse 4G Forums
928K posts
23.8K members
Since 2007
