| Tuning and Electronics This forum is for tuning devices for the 4g eclipse from piggyback systems to full Stand Alones, Fuel Controllers, EGT readings, Data logging, PCM tuning, Air/Fuel readings and data. Discussions of Installations, Wiring & Tuning. |
Did u see GT on the back?
2006 Eclipse GS W26
Fi/c maps: 4g69
**POSTER OF ANY MAP IS NOT RESPONSIBLE FOR ANY OTHER USER HAVING ANY TYPE OF ISSUES WITH HIS/HER MOTOR
If you post a MAP please Include the following information. ie: Motor: 4G69T Injector's: 440cc injectors (If other than stock) N2O Shot: if applicable Charger: Turbo (or Super if applicable) try to post a brand and model as well ie: TD04-14b Boost: 7psi and 10 psi (if applicable) BOV Type: Atmosphere (if applicable) Location: Florida Temperature: Spring Condition's Supporting Mods: Stock Internal's (if applicable) If I missed anything, or there is something else you think should be up here let me know.
"No, no, no, light speed is too slow. We're gonna have to go right to MIVEC speed." |
2006 Eclipse GS W26
Hey guys anyone have a N/A Map to share with a MAF Pass thru map in it
2006 Eclipse GS W26
Motor: 4G69T
Injector's: 440cc injectors Charger: Turbo Boost: 7psi and 10 psi BOV Type: Atmosphere Location: Florida Temperature: Spring Condition's Supporting Mods: Stock Internal's
06 Eclipse GT
Dude...is your car running with that 10psi map in there??? It's WAY out of whack on the MAF line...
2006 Eclipse GS W26
No Brian I am not running that map. When we started this thread Mecks gave it to me to post for him I just now got around to posting is it all
06 Eclipse GT
Wow...did his car run with that???
I wouldn't put that in a car like that...it's modifying the MAF signal WAY too much...that's gonna cause problems with ignition timing and fueling...You shouldn't even need to be messing with the MAF sensor other than to MAYBE clamp it under boost...
2006 Eclipse GS W26
Really cause his car was running good, and I think he had it tuned somewhere
2006 Eclipse GS W26
Motor = 4G69
This is a Pass Through MAP only. The only change is the MAF MAP has been set-up as a pass through to get the car running. It is only written so The MAF line sends out the same thing it recieves
"No, no, no, light speed is too slow. We're gonna have to go right to MIVEC speed." Last edited by DarkSidEclipse; September 10th, 2010 at 09:52 PM. |
#9 (permalink) | |
06 Eclipse GT
In other words, by changing voltages in the MAF table like that it will affect timing and fuel at those locations...which you will then have to go to the fuel map and change it to correct for what the MAF table is doing...same thing for the ignition map. Seems to me in a turbo setup you'd just want to leave the MAF alone, maybe clamp it as necessary, and do all the tuning directly in the fuel and ignition maps...much simpler and it's how the FIC was designed. I would have left the MAF map completely alone and done the tuning in the fuel and ignition tables only...but if it worked it worked...just was alot MORE work!
David
06-GS-Titanium Pearl
Just upgraded my F/IC to 3.04, and bumping to the top.
Performance: AEM F/IC w/ BilletProof PNP Harness, AEM UEGO Wideband, 2.5" Catback Exhaust w/Dual Outlets, Fujita CAI, Ported Intake Manifold with GT TB Swap, Ralco RZ Short Shifter, RPW Thermal Spacer Kit, RRE SS Race Header Suspension: Evo Brembo Swap, Front: Cusco Strut Tower Bar, Custom Tein Coilovers with D2 Camber Plates Rear: Eibach Sportlines Springs, KYB GR-2 Shocks |
2006 Eclipse GS W26
Dave are you running an AFR with your FI/C setup as an aux gauge?
David
Yeah, I am running a AEM wideband. I've done a lil road tuning with my friend, and pulled some fuel but that's about it. Loaded the passthru you posted for now. I'm gonna load that turbo map just I can see what the tables look like for I have not seen a map before.
2006 Eclipse GS W26
Motor: 4G69
Injector's: Stock Location: Tenn, KY Border Temperature: Spring/Summer condotions a constant 80 to 100 degrees Supporting Mods: RRE Header, Third Cat removal, Magnaflow Catback, Fujita Intake, RRE UDP, GT Throttle Body This is a MAP I have been working on for a while. It has a slight timing advance, very slight not much. The fuel Trims are almost perfect around 12.7-13.2 through out a whole 3rd gear pull. You might have to add or take away fuel depending on your climates temp.
2006 Eclipse GS W26
Keep in mind this a mild timing change, and not a big one for off the wall numbers. This is mainly to maximize your mods and get the fuel trims around where they should be. You should notice a difference it might be big it might be little, really depends on where your fuel trims are at now. I think the guys with a GT TB will notice more than anything. That was the mod I had to adjust for the most. To get my MIVEC kick back.
David
I went to the track a couple weeks ago and wanted to do a few datalog passes. This is the first time I ran my F/IC since I've upgraded it. I've had the bypass on it, because I do not know how to make a map. I plugged it in, and took a run down the track. I was getting a hiccup in the high RPM's. Just wanted to know if anyone else has experienced that.
I'm going to load up the map you just posted, and see how my car reacts to it. I will post up when I do.
#16 (permalink) | |
2006 Eclipse GS W26
06 Eclipse GT
I wouldnt say that...as the FIC is controlling the injectors all the time. There shouldn't be a miss or hiccup at all...
travis
07 eclipse gs-n
hey brian i got a question. is there a way to have the FIC retard timing when nitrous is activated.
06 Eclipse GT
Yep, you can switch the whole map if you want!
#20 (permalink) |
travis
07 eclipse gs-n
i cant wait to get my harness now
#21 (permalink) | |
Jon
2008/Eclipse/Not a GT ; (
#22 (permalink) |
2006 Eclipse GS W26
I had to add a lot of fuel for the throttle body so your most likely going to be really rich from 3500 + rpms.
#24 (permalink) |
2006 Eclipse GS W26
17-18 complete and total top end power loss
#25 (permalink) |
2006 Eclipse GS W26
Motor: 4G69
Injector's: Stock Location: Tenn, KY Border Temperature: Spring/Summer condotions a constant 80 to 100 degrees Supporting Mods: RRE Header, Third Cat removal, Magnaflow Catback, Fujita Intake, RRE UDP, GT Throttle Body A little more advance and little richer. If you don't have the GT TB this is going to be way to rich for you. *Side note I would not recommend the GT TB for anyone who can not tune for it *
#27 (permalink) |
Loves haters !
09 5 speed manual
wierd that your running that lean with the tb.medave stated it made the car run a lil richer,not leaner in the gs to gt tb swap thread.
Modified Last edited by snakeeyes; July 26th, 2011 at 06:35 PM. |
#29 (permalink) |
David
I have seen some top end power loss, but it was when I switched to a 2.5 catback setup. As for running lean, I have not seen that at all for the 2 yrs I've been running with the GT TB. If my car was running that lean with any mod I would of put it on blast here on the forum and immediately removed it. In fact this is the first I've heard of anyone running so lean.
I loaded your map, and I had a violent hiccup. I forgot my usb cord at home and so I couldn't datalog it, but looking at my wideband it went super lean for a split second and then took off. I will load it again and have a friend with me next time so we can monitor and datalog it. After the hiccup it ran fine and AFR's were good, but it was real bad.
#30 (permalink) |
travis
07 eclipse gs-n
i dont have any lean issues with my car and the gt tb. i run rich.
#31 (permalink) |
06 Eclipse GT
Yeah, rich is normal...if the car is running that lean, most likely there's a MAF sensor issue.
#32 (permalink) | |
2006 Eclipse GS W26
I am sure if you played with the timing numbers a little an pulled them back a little you could find some happy medium in the fueling without touching the fuel map. Dave as far as the hiccup I am not sure I am not experiencing that all. The closest thing I would have to anything like that is a little torque steer when MIVEC hits from the additional torque.
"No, no, no, light speed is too slow. We're gonna have to go right to MIVEC speed." Last edited by DarkSidEclipse; July 28th, 2011 at 08:25 AM. |
#33 (permalink) |
travis
07 eclipse gs-n
how bad is it that i noticed a wot at 6k rpm my afr is 10.8:1
#34 (permalink) |
2006 Eclipse GS W26
10.8 you are losing power
#35 (permalink) |
travis
07 eclipse gs-n
yeah that might explain that lagging feeling and huge fuel consumption problems. i really need to get the fic hooked up to fix that.
#36 (permalink) | |
2006 Eclipse GS W26
Tomorrow i will post what i finally ended up with. Pretty steady 12.5 pull went a little richer. It just felt better than 13
#38 (permalink) |
2006 Eclipse GS W26
Motor: 4G69
Injector's: Stock Location: Tenn, KY Border Temperature: Spring/Summer condotions a constant 80 to 100 degrees Supporting Mods: RRE Header, Third Cat removal, Magnaflow Catback, Fujita Intake, RRE UDP, GT Throttle Body Fuel: 93 Octane A little more advance and little richer. If you don't have the GT TB this is going to be way to rich for you. Everything under MIVEC is as stock, 3400 is when timing and fuel change
#39 (permalink) |
06 Eclipse GT
??? ^^^ your Mivec starts at 3400???
#40 (permalink) |
Jon
Yeah....mine hits at 4000.
| 4g69, brand, injectors, mods, stock, super, turbo |
