| Tuning and Electronics This forum is for tuning devices for the 4g eclipse from piggyback systems to full Stand Alones, Fuel Controllers, EGT readings, Data logging, PCM tuning, Air/Fuel readings and data. Discussions of Installations, Wiring & Tuning. |
#41 (permalink) | |
'05 Lancer Ralliart
I just need 2 know where to send them. I can't upload jpeg's here. PM me... or I can upload them to cardomain and you check them out from there... OK, pics at: http://www.cardomain.com/ride/2667426/6 at the bottom. EDIT: Direct links to pics: http://memimage.cardomain.com/ride_i...0270_large.jpg http://memimage.cardomain.com/ride_i...0271_large.jpg http://memimage.cardomain.com/ride_i...0272_large.jpg http://memimage.cardomain.com/ride_i...0273_large.jpg http://memimage.cardomain.com/ride_i...0274_large.jpg http://memimage.cardomain.com/ride_i...0275_large.jpg From what I've read, they tried the FIC directly into the MAF wire (white/red for the RA) with no success. There was something about not making any changes in output voltage and misbehavior from the car itself with random misfire, CEL's coming up, that sort of thing. The fact is that, not many people have tried this, so everyone that reads about it just post in forums that it won't work because a friend, of a friend, of a friend, etc., said it wouldn't. Locally, people here tend to go the cheapest way possible with those magical manipulation of sensors by touch (i.e. cam sensor and crank sensor adjusment, which cost nothing but a little time to do, washers in the exhaust piping, unplugging vaccum lines, and a lot of shit like that) and then testing them on the "Butt Dyno" to say "You can feel the kick". I bought the Federal Emissions ECU to solve my Cali ECU problem, which was close to $200. I can get a new FIC (6, right?) for about $350, and I don't know how much you would charge me for the PnP harness. All of this will probably add up to what RRE charges for the 4G AEM kit, but I don't have a 4G and I'm trying to get as far as I can with this. At the end, if it's possible, a whole new range of customers will line up for this solution (RA owners I mean), but if it doesn't I think I'll probably get half of what I've spent back, probably sell the car and just get one that I can do a lot with (not anytime soon though)... As for the FSM, it's about 300MB... Do you know of an easy way for me to send this to you? Let me know... Carlos Last edited by cianuro; September 23rd, 2009 at 09:15 AM. |
| Club4G Sponsors |
#42 (permalink) |
Did u see GT on the back?
2006 Eclipse GS W26
"No, no, no, light speed is too slow. We're gonna have to go right to MIVEC speed." |
#43 (permalink) |
06 Eclipse GT
Ok...those plugs are definitely not the same as the 4G...however, that doesn't mean much right now. You have a few options...I can find out what plugs they are and see if they're available individually (most likely not cost effective...but it's possible), or, if nothing else, I can get the terminals for the plugs and you can swap the pins like we do on the 4G. A third option would be for me to just make you a flying lead harness from the FIC to the ECU and you would have to cut and splice just like you normally would have to do. Only difference would be that the harness would already be completed, labeled, and ready to go WITH the MAF circuitry built-in. If you wanted, I could also put plugs on the ECU side so that you could easily remove the harness and plug the stock wires back in quickly.
Bottom line is that we can work it out a number of ways...but I'm sure the FIC will work, just that no one knew how to get it to interface the MAF properly... Find a way to get that service manual to me...send it in the mail if you have to...let me know... brian
#45 (permalink) | |
'05 Lancer Ralliart
I bet Split Second did find the way to interface, but they don't sell the FIC !!!Let me see if I can get a break at work to figure out how to send you the FSM. I'll be out from work at 10pm or so, so I'll also check the possibility of creating a torrent for you to download, or a space I have for website which I haven't used in a while. Talk to you later, Carlos |
#46 (permalink) |
06 Eclipse GT
Well, if you don't mind that then I could make a real nice flying lead harness for you, completely labeled, with the MAF circuit built in...you'll just have to buy the FIC and send me the pigtail harness that comes with it...I'll attach that to your harness and you'll be good to go. I'll just need some dimensions from you, like where the ecu is and where the FIC will be inside the car, etc.etc.
#47 (permalink) | |
'05 Lancer Ralliart
![]() That'll be fine, once I get the FIC. So, we've solved most of the issues that were bothering me before making the decision on going with the FIC. I'm still trying to find a way to get the FSM to you, and all that's left is pricing... I know you will take your time and money to make this happen, and I'm not looking for a free ride. How much would you charge me for that "Flying Lead Harness"(answer via PM)? Remember, I'm being the guinea pig here, so please treat me well. If this doesn't work (which I don't think will happen), I would probably place everything for sale at eBay or something like that just to make sure I get some of the investment back. If it does work, your name would placed by me on every forum I find this issue. Us RA owners have been looking for something like this, and most of the guys I know have one are like me, not caring 'bout splicing or cutting, as long as it works. This would be a great breakthrough (alongside the reflash if you don't wanna go piggy) for the Lancer RA and will open new opportunities that I know won't be taken for granted. Do you have a torrent client software, i.e. utorrent? I've uploaded the FSM as a torrent, so I will leave my PC on for you to download from it. Click this link: 2006 Lancer Service Manual : Books > Manuals - Mininova where you'll have direct access, but you need utorrent (or something like it, but this is the one I've been using for a while and it works fine). Once you click on the link, choose open, not save, then it'll start downloading through utorrent. (If this option is in any way wrong according to forum rules, please let me know so I can remove the info) Need anything else from me? Remember, guinea pig, treat me well, etc. PM me... Carlos |
#48 (permalink) |
06 Eclipse GT
I'm downlaoding the manual now...but damn, it says there's like 10 hours left...??? Anyway, it's downloading...so we'll see what's up when I get it...
*EDIT* Yeah, I'm not sure this torrent thing is going to work...it keeps stopping, and saying it's going to take weeks to finish the download...the file is only 248Meg on my connection that should only take a few minutes to download...
Home of BilletProof Racing and the 4G SCM.1 Shift Control Module, the PnP harness for the AEM F/IC, and the Timing advance solution for the F/IC Last edited by BrianJ; September 24th, 2009 at 03:32 AM. |
#49 (permalink) | |
'05 Lancer Ralliart
Torrents work by gathering bits and pieces of every computer with the file that has the torrent client open. Since I was the only one when it started, it will rely in my connection. It will need to be in at least 2 computers for it get more speed. Give it a while, just let it work its way through... I'm trying another way... I'll PM you with it if I get it to work... |
#50 (permalink) |
06 Eclipse GT
ok, I got the manual...second way was much easier...just a few minutes...
You have an issue though...I was reading in the manual, and it appears that there are actually two different MAF sensors for this car... First thing I need to know is which engine you have...the 2.4 or the 2.0...?
#51 (permalink) |
06 Eclipse GT
Actually, we're WAYYYY off topic here...let's just talk in PM's from now on...thanks.
#52 (permalink) |
Lathe Master
07 Eclipse GT
At what point would one want to bump up the timing of an all motor car? I'm assuming after you've acheived a stable 11.7 to 12 AFR at WOT and you're happy with the fueling??
My plan once I get everything running is to get the AFR where I want it first, then add timing. Is this the right approach??
#53 (permalink) |
06 Eclipse GT
Do the timing first...it'll lean the car out...then go in and adjust fueling. Also, 11.7:1 is still way too rich on a N/A car IMO...you'll get much better results at the 13:1 mark...we noticed a sizeable gain going from 12:1 to 13:1...I personally run mine at 13.0 - 13.3
#54 (permalink) |
Lathe Master
07 Eclipse GT
So you don't think 13 is too mean? I'm assuming that would produce pretty much the best power for the car all motor though. If the car gets too lean with the FIC in control of fueling can't you theoretically blow it up?
#55 (permalink) |
06 Eclipse GT
You'll get different people telling you different thing about what AFR to run...IMO, 13:1 is the best mix of performance as well as longevity...
As for "blowing up the car" with the FIC...my answer would be that it's really not very likely. Keep in mind that you still have your stock ECU in place with all of it's safegaurds...if you leaned it out too far, you'd start to get knock, the ecu would see that and pull timing to keep it from hurting anything. But honestly, you'd have to lean it out quite a way to see any of that activity... It's actually kind of hard to blow up a stock motor these days with all the safety stuff in the ECU. You have to be boosting or using nitrous improperly or doing some other internal non-stock modifications...using simple bolt one and doing some fuel tuning with the fic shouldn't cause you any major issues.
#56 (permalink) |
Lathe Master
07 Eclipse GT
Thats exactly what I was wondering, if I push the car too far will it know enough to pull timing. Thats good to know. We'll see how the car responds when I get to that point. Looking forward to feeling the difference!
On a side note Brian what sized holesaw should I pick up for the FIC firewall hole? Is it the same size for the uego? I'll be doing this at the same time, so I'll probly put the holes right next to each other.
#57 (permalink) |
2006 Eclipse GS W26
Agreed if you go through the dyno thread and look at some of the sheets a couple of them have crazy high AFR's. The guy with the N2O on his GS hit like 16 on his AFR's and didn't blow his engine lol. I think 13 is a good place on these Motor's N/A.
#59 (permalink) | |
06 Eclipse GT
| Club4G Sponsors |
