FINALLY, Ignition advance with the FIC revealed!!! - Page 3 - Club4G Forum : Mitsubishi Eclipse 4G Forums - 2006-2012 Eclipse Authority
Old May 8th, 2011, 03:51 PM   #81 (permalink)
The Unofficial Mod-erator
Live4Redline's Avatar
Vehicle: 2006 Evolution IX
Live4Redline has a reputation beyond reputeLive4Redline has a reputation beyond reputeLive4Redline has a reputation beyond reputeLive4Redline has a reputation beyond reputeLive4Redline has a reputation beyond reputeLive4Redline has a reputation beyond reputeLive4Redline has a reputation beyond reputeLive4Redline has a reputation beyond reputeLive4Redline has a reputation beyond reputeLive4Redline has a reputation beyond reputeLive4Redline has a reputation beyond repute
I could have swore it was a little more then 23'ish but its been awhile so I'm not sure. I wanna say it hit into the low 30's but i may be wrong. Might test it later if i get bored.
My cars been in daily mode for awhile so I'm starting to forget some of these figures i once knew off the top of my head.
^ Sold my 06 Eclipse GT-5, 07 Eclipse GT-6 and 06 Eclipse GS-4
+++ Daily: 2003 Lancer ES & 2005 Montero Limited +++
----- AutoX/Track: 2006 Lancer Evolution IX GSR -----
< First 4G Eclipse to break 300+ all motor! (311 whp and then some)
Live4Redline is offline   Reply With Quote Quick reply to this message
Old May 8th, 2011, 04:25 PM   #82 (permalink)
^ Just went and did a highway pull for ya, so you should feel special atm...
  • Idle is 7-12.
  • Partial Throttle and Cruising was 35-45.
  • Full Throttle before MIVEC was 24'ish
  • Full Throttle after MIVEC was 27 with a firm climb to 32.
Keep in mind I'm also throwing 0 codes and check engine light free, with a perfect 0.0 fuel trim. /props to me
Old May 8th, 2011, 07:59 PM   #83 (permalink)
Lathe Master
Ricoswave's Avatar
Vehicle: 05 Lancer Evolution
Interestingggg. I'll have a look at that when I do another pull.
Mods:
Ricoswave is offline   Reply With Quote Quick reply to this message
Old May 8th, 2011, 08:00 PM   #84 (permalink)
Lathe Master
Ricoswave's Avatar
And thanks a tonnnn
Mods:
Old May 9th, 2011, 05:13 PM   #85 (permalink)
Lathe Master
Ricoswave's Avatar
Yeah dude I'm not seeing any more than 24 at wot in Mivec.
Remember I'm untuned right now, I'm looking for stock numbers.
Mods:
Old May 9th, 2011, 05:22 PM   #86 (permalink)
Vehicle: 06 Eclipse GT
24 sounds right untuned...if I remember right I was doing about 31 after I dis the timing advance...
BrianJ is offline   Reply With Quote Quick reply to this message
Old May 9th, 2011, 06:45 PM   #87 (permalink)
Lathe Master
Ricoswave's Avatar
If you get a sec brian can you load a passthru and scope it out on the dashhawk for me? Id appreciate it!!
Mods:
Old May 15th, 2011, 08:56 PM   #88 (permalink)
Lathe Master
Ricoswave's Avatar
Just to add a little update, I seem to have gotten some midrange power back by tuning just the fueling, and running passthrough maps on the MAF. (voltage in = voltage out).
Still have a tiny hiccup in the tune somewhere, I just have to figure out where the skips is.
I'm not doing timing advance anymore, because I'm dialing in the car for nitrous.
Mods:
Old July 1st, 2011, 01:56 PM   #89 (permalink)
Vehicle: 2007 Mitsubishi eclipse
Alain0124 is on a distinguished road
Hello, can anyone poat up the link to where I can buy the fic and harness. Thank you forum
Alain0124 is offline   Reply With Quote Quick reply to this message
Old July 1st, 2011, 02:17 PM   #90 (permalink)
Has A Big Member
stangcobra's Avatar
Vehicle: 01 svt cobra
Jesus christ, someone ban this kid, all he does is post in the wrong threads and ask to buy shit
stangcobra is offline   Reply With Quote Quick reply to this message
Old July 1st, 2011, 06:02 PM   #91 (permalink)
Steering Wheel Delete
forsworn71's Avatar
Vehicle: '06 Eclipse GT
forsworn71 is a glorious beacon of lightforsworn71 is a glorious beacon of lightforsworn71 is a glorious beacon of lightforsworn71 is a glorious beacon of light
Dude...look at the RRE website before you post another post
Eclipse: Totaled
New Toy: MazdaSpeed
3
Muffler Delete - Injen CAI - Alpine Type R 12' Subwoofer - Pioneer AVIC F90BT - Short Shifter
forsworn71 is offline   Reply With Quote Quick reply to this message
Old July 12th, 2011, 06:19 PM   #92 (permalink)
deprydation's Avatar
Vehicle: 2012 Lancer Ralliart
deprydation is a splendid one to beholddeprydation is a splendid one to beholddeprydation is a splendid one to beholddeprydation is a splendid one to beholddeprydation is a splendid one to beholddeprydation is a splendid one to behold
Brian,
I couldn't PM you cause your box is full!!! :/
I might be able to get my hands on a FIC harness. How much would you charge me to send you the harness and get it made into one of yours for the GT?
-Will
Current Car: 2012 Mitsubishi Lancer Ralliart: Evo X FMIC | MAP UICP | Evo X LICP| Evo X BPV | AEM Intake | AMS Boost Pill | GST Basemap Tuned by ME! | RRM GRIP Springs | Oil Catch Can | Agency Power 3" DP | Avid1 18x9 +35 | Project Kics R28 Lugs | AMS 3" Resonated TP | Ultimate Racing 3" Dual-Tip Catback | Zeitronix ZT-2/ZR-2 AFR+Boost |
deprydation is offline   Reply With Quote Quick reply to this message
2.4, back, car, eclipse, ecu, fic, fuel, good, injectors, lower, mitsubishi, mivec, move, racing, rre, setup, show, sick, stock, street, timing, top, tuning, uni, work
