Crank but wont start!!! After ECU remove. - Club4G Forum : Mitsubishi Eclipse 4G Forums - 2006-2012 Eclipse Authority
Old November 7th, 2015, 01:31 PM   #1 (permalink)
Vehicle: 2011 Mitsubishi Eclipse
adrianglez305 is on a distinguished road
Hello everyone, I'm new so I really don't know how to use the forum that well.
Sorry if there was a treat on this already, but I couldn't find it.
Let me start from the beginning with details.
I bought a 2011 eclipse gs sport 2.4 50k miles from the car auction (iaai) it runs and drive like a dream. Just need it the front bumper, headlights and drivers airbag replace, is fixed already, but all the lights in the cluster stays on while the car is running. (Srs, check engine, low tire pressure, emergency brake, etc.) I was told I need it the airbag module reset, do with hard codes. I send the ecu thinking that was it (i send it to myairbags on ebay 40$ reset) thats when the problem start.
I remove the ecu without disconnecting the battery and put it in a box to ship. Then I need it to move the car to the side, the car cranks but no start, I put the ecu back and the car starter right away. I move it to the side, remove the ecu and send it. Two weeks later I receive the ecu put it back and the car cranks but no start. I try removing the battery with the ecu on the car no luck I also try this:
Unplug the battery from the car
Let the car sit for fifteen (15) minutes unplugged.
Install the new ECU
Reconnect the battery
Turn on the AUXILIARY switch (ignition half way to where all the lights come on - at this point the "Check Engine" light needs to be ON... if it's on then the ECU is in working condition).
Let sit for another five (5) minutes
Turn off the car
Turn the ignition, car should start right away.
No luck any help will be very appreciate. Thanks Adrian.
adrianglez305 is offline   Reply With Quote Quick reply to this message
Old November 7th, 2015, 04:17 PM   #2 (permalink)
Super Moderator
Here's my experience: Don't go to a dealership for ECU no start problems. Their hardware will read a communication failure even if it's alive, and they'll try to get you to pay around $1000 to order one from Japan on a huge waiting list. If you can find one at a junkyard with the same engine with the same model # (eg, mine is "1860A993") you SHOULD* be able to swap it in, but at that point is where it becomes hearsay as I don't know anybody who has. There are also people who can properly reset the software in the ECU
Do you get a CEL at step 5?
Also, did you ever try to start the car after you took the ECU out with it running?
March COTM VOTING form
Old November 9th, 2015, 10:24 PM   #3 (permalink)
Hi thanks for the reply.
yes im definitely not going to the dealer! very bad experience with them.
no i didn't try that. all i did was to remove the ecu while the car was off, but the battery was connected though.
Old November 10th, 2015, 12:26 AM   #4 (permalink)
Okay, think of your ECU like a key, even like your car key. If you clear the code for you car key it will no longer work, reprogram the key to your car/ECU, your key will work again.
So I don't know what they did when you sent your ecu in for them to clear the code, but!!
The SRS system is regulated by Federal Law, in order for this code to be reset the dearlership or authorized party must check the SRS system before resetting this code.
When reinstalling an ECU there are procedures for reinstalling the ECU, some of these procedures involves resetting and reprogramming codes. There are five other onboard computers that talks with the main ECU, ABS, Engine, transmission, SRS, electrical, radio, and anti-theft, soooo.
You can start by checking for Codes on the OBDII Port, if you have any codes post them, especially any U0xxx codes.
You may have damaged a pin, or plug on one of your connectors.
Eclipse Factory Service Manual Link:
GROUP 54C CONTROLLER AREA NETWORK (CAN)
http://tearstone.com/eclipsefsm/2006...002300-54C.pdf
GROUP 54B SIMPLIFIED WIRING SYSTEM (SWS)
http://tearstone.com/eclipsefsm/2006...002200-54B.pdf
CHECK AT ECU TERMINAL Page 54B-547
Old November 13th, 2015, 12:11 PM   #5 (permalink)
hackish is just really nicehackish is just really nicehackish is just really nicehackish is just really nice
The immobilizer is going to rain on your parade. The dealer will often tell you that it's not possible to re-key a scrapyard ecu and you have to buy a new one. I can reprogram them and disable the immobilizer but I'm nowhere near florida.
-Michael
Designer of the 4G Eclipse Reflash. Please do not send PMs as this account is not monitored. Contact sales@fastworks.com or support@fastworks.com
"The good thing about science is that it’s true whether or not you believe in it" -Neil deGrasse Tyson
hackish is offline   Reply With Quote Quick reply to this message
2.4, 2011, 2011 eclipse, airbag, back, battery, box, brake, bumper, car, crank, drive, drivers, eclipse, eclipse gs, ecu, ecu flash, electrical short, engine, front bumper, headlights, how to, ignition, king, problem, remove, starter, tire
Car won't start..? CuTi08 Problem Reports 26 August 12th, 2015 06:29 PM
Changed timing belt, know car won't start. No fuel or spark. ElQuickness Problem Reports 16 March 30th, 2015 01:02 AM
P&P Remote Start Bretts 2006-2012 Eclipse (General 4G) 0 December 12th, 2014 12:48 PM
I-J Crank Scraper Installation RalliartN 4G Eclipse GS/SE Specific 0 July 29th, 2014 08:44 AM
2008 eclipse 2004 no crank or start help! breadman001 Problem Reports 6 July 20th, 2014 09:30 AM
