Disabling Steering Wheel Lock - Club4G Forum : Mitsubishi Eclipse 4G Forums - 2006-2012 Eclipse Authority
Old March 5th, 2016, 02:14 PM   #1 (permalink)
Vehicle: 2009 Eclipse GT (Solar)
Lumenix is on a distinguished road
Ive just recently gotten a new alarm system installed and included is a keyless push to start system. Very cool stuff except for the fact that I need to insert the physical key to unlock the steering wheel. I tried taking a look in the steering column for the mechanism that does this but cannot see much without a full dismantle.
To be clear, what Im talking about is the security feature that kicks in when you turn the wheel without the key and it locks in place, making the car undrivable. Has anyone found out where to disable this? Its most definitely a mechanical system and Im guessing a simple removal of a spring or pin somewhere would fix it.
EDIT: Ive made some progress, Ill update here for the sake of others wanting to complete this project.
EDIT2: In order to disable the steering wheel lock you will need to pop open the steering column plastic shell. If you lay on the floor of your vehicle and look up youll see where the ignition key cylinder intersects with the steering column. On the underside, directly where they intersect youll see a metal "panel" of sorts. You cant remove this without giving yourself a headache so what you want to do is drill straight up into it. Just breach the panel. Once you do you can use a pair of needle nose pliers and pull out a small spring, this is what forces the lock pin into the steering column. For safety sake I removed the entire ignition component and applied a little adhesive to the pin so that it wont bounce up while driving.
Lumenix is offline   Reply With Quote Quick reply to this message
alarm, art, car, clear, cool, fix, keyless, kicks, lock, locks, removal, security, start, steering wheel, stuff, system, unlock, wheel
Plea for help (need wheel lock) Hensen Texas 5 February 4th, 2016 12:42 PM
How stiff is your steering wheel? pieandcake123 2006-2012 Eclipse (General 4G) 8 September 21st, 2015 10:46 PM
Steering wheel radio controls not working LAFINESTS Problem Reports 3 August 17th, 2015 10:10 PM
Steering Wheel Vibration Manvir Problem Reports 3 October 20th, 2014 07:36 AM
FS/WTT: Pioneer AVH p4000dvd With Mito 01 & Steering Wheel Interface Animefreak1983 Automotive For Sale/Wanted 12 August 11th, 2014 09:10 PM
