88K views 147 replies 43 participants last post by  78372
I seen something similar to this in the GT section. I noticed we don't have one and even though a lot can apply from that thread to our cars also, we need a "go-to" thread for all members w/ a GS to come to for ideas on what to do with their ride next. This could also help prevent a lot of "I'm new what mods should I do" threads. I will update this thread constantly and would love for members to chime in and help make this perfect. These may not be the best prices but they are the upgrades themselves.
Great Sites to Buy From
http://www.ultrarev.com/cai4006.html
http://www.autocityimports.com/2006-eclipse-c-54_1176.html
http://www.roadraceengineering.com/4g.htm
http://www.summitracing.com/search/Year/2006/Make/MITSUBISHI/Model/ECLIPSE/
www.oemmitsubishiparts.com
www.car-part.com
http://www.ddmtuning.com/
Engine
GT throttle body- http://www.oemmitsubishiparts.com/ (ebay, google, or post wtb thread in forum)
Send tb to Proflow for rebore
Can bypass the throttle body by using a 3/8th's barbed coupler to connect both coolent lines- www.autozone.com
RRE Underdrive Pulley- 2006+ Mitshubishi Eclipse (2.4 MIVEC) RRE Underdrive Pulley Kit Sport Compact Auto & Import Performance Superstore
RRE Forged Aluminum Pistons- Road Race Engineering's 4G Eclipse Parts and Performance
4g63 pistons (w/ 87mm Bore)*Wiseco forged pistons*- www.importperformanceparts.net
Port and Polish- Delta Camshaft
RPW Thermal block Intake Manifold and tb spacers- http://www.rpw.com.au/shop/index.ph...product_id=112&category_id=283&option=com_virtuemart&Itemid=1&vmcchk=1&Itemid=1
RPW cams*- www.rpw.com.au
Regrind our Cams by DELTA Cams (may just be GT Specific)*- http://deltacam.com/
Oil Catch Can (Universal)
Mitsimoto MMOC Oil Cooling Kit*- http://www.frsport.com/Mishimoto-MMOC-UL-Universal-19-Row-Oil-Cooler-Kit_p_24708.html
7 bolt 4g63 rods*- (upgrade from factory)
ARP 4g63t 7 bolt main and cylinder head studs*- (Upgrade from factory)
4G63 EVO balance shafts (can use 4G63 EVO BS eliminator kit )
4G64, 4G94 valve guides and seals
4G64, 4G94 valve spring retainers
EVO timing belt tensioner which is aluminum, not cast iron
'00-'07 Lancer Ralliart Intake Manifold* (Nearly Plug and Play)
Ingalls stiffy engine torque dampers*(Maybe)***- http://www.summitracing.com/parts/IEC-93037/, template made by member- http://club4g.org/board/4g-eclipse-gs-se-specific/24108-gs-stiffy-naughty.html
Energy Suspension Motor Mounts*- http://www.summitracing.com/parts/ENS-5-1113G/
High pressure Radiator Cap*- http://www.ebay.com/itm/27038486381...m/270384863816?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1439.l2649#ht_1041wt_976
GS Stiffy Skematic*- http://club4g.org/board/4g-eclipse-gs-se-specific/24108-gs-stiffy-naughty.html
Thermal Shield - http://www.thermotec.com/products/all.html
Can find many parts from wrecked cars including GT tb's here*- http://www.car-part.com/
*Most parts from the Lancer 4g69 engine can be direct bolt on w/ some work and patience to upgrade our engines.*
Headers
RRE GS Headers - Road Race Engineering's 4G Eclipse Parts and Performance
Gut Stock Exhaust Manifold Cats
OBX Longtube Headers (Get coated and wrapped*) - OBX Stainless Steel Header 06-09 ECLIPSE GS 4G69 2.4L
RIPP Mods Headers*- (Must find used via ebay or the club, RIPP no longer makes these)
Intakes
Injen SRI- 2006+ Mitsubishi Eclipse (4Cyl Automatic) INJEN Short Ram Intake Sport Compact Auto & Import Performance Superstore
Injen CAI (Manual)- 2006+ Mitsubishi Eclipse (4Cyl Manual) INJEN Cold Air Intake Sport Compact Auto & Import Performance Superstore
DC SPORTS CAI- DC Sports COLD AIR INTAKE SYSTEM - UltraRev.com - Part# CAI4006
Fujita CAI- 2006+ Mitsubishi Eclipse (4Cyl) Fujita Cold Air Intake Sport Compact Auto & Import Performance Superstore
Weapon-R SRI - Auto City Imports : Sport Compact Auto & Import Performance Superstore
Injector/ Fuel Delivery
NGK Iridium one step colder spark plugs- NGK Spark plug, NGK Spark Plug wire, NGK Platinum Spark plug for High Performance and Racing. - stock #: 2309 part #: LFR7AIX
02-05 USDM OEM Subaru WRX 440cc Injectors
JDM Subaru STI Pink 565cc Injectors
89-92 RX-7 Injectors
Lancer 4g69 Injectors* (Not 100% confirmed)
Lancer 4G69 Fuel Rails* (Not 100% confirmed)
Suspension
Tanabe Strut tower bar- 2006+ Mitsubishi Eclipse TANABE Strut Tower Bar (Front) Sport Compact Auto & Import Performance Superstore
WORKS adjustable rear sway bar*- http://www.autocityimports.com//2006-mitsubishi-eclipse-works-adjustable-sway-bar-rear-p-4913.html
Tanabe Lower tie bar- Road Race Engineering's 4G Eclipse Parts and Performance
Eibach Lowering Springs- Road Race Engineering's 4G Eclipse Parts and Performance
Megan Racing Coilovers- Road Race Engineering's 4G Eclipse Parts and Performance
BC Racing Coilovers*- http://www.autocityimports.com/2006-mitsubishi-eclipse-bc-racing-coilovers-br-series-p-9351.html
Tien SS Coilovers*- http://www.autocityimports.com//200...ubishi-eclipse-tein-ss-coilover-damper-kit-w-pillowball-upper-mount-p-7334.html
D2 RS Coilovers*- http://www.jmautoracing.com/racing20062011-mitsubishi-eclipse-coilovers-p-44794.html
KW Coilovers*- http://www.andysautosport.com/mitsu...shi/2006_9999_eclipse/suspension/coilovers/full_coilover_systems/kw_suspension/
XYZ Full Coilover System- http://www.andysautosport.com/mitsu...om/mitsubishi/2006_9999_eclipse/suspension/coilovers/full_coilover_systems/xyz/
RRE Adjustible Rear Sway Bar- Road Race Engineering's 4G Eclipse Parts and Performance
Energy Suspension Bushing- Road Race Engineering's 4G Eclipse Parts and Performance
WORKS Lowering Springs*- http://www.autocityimports.com//2006-mitsubishi-eclipse-works-lowering-springs-p-4912.html
GT Struts bar can be found fairly cheap also*- (ebay, forums, google)
Energy Suspension Rear Trailing Arm Bushings*- http://www.summitracing.com/parts/ENS-5-7115R/
Eibach Anti Roll kit front and rear sway bars*- http://www.autocityimports.com//200...06-mitsubishi-eclipse-eibach-antiroll-kit-front-and-rear-sway-bars-p-10033.html
Handling/Traction Specific
Aluminum or CF wing*
Performance Tires (Stock size = 225/50/17)
Brake Kits
Royalty Slotted and Drilled rotors- 2006+ Mitsubishi Eclipse (GS 4cyl) Royalty Slotted & Drilled Rotors (Front and Rear) Sport Compact Auto & Import Performance Superstore
Brembo Brakes Evo8/9- (Not sure where to find other than EVO forums or Google)
Stop-TECH Big Brakes- Road Race Engineering's 4G Eclipse Parts and Performance
Stainless Steel Brake Lines- http://www.roadraceengineering.com/4g.htm
Tuning/Electronic
AEM FIC w/ Harness - Road Race Engineering's 4G Eclipse Parts and Performance
Reflash ECU by Hackish
Triple gauge Piller Pod- 2006+ Mitsubishi Eclipse Triple Gauge Piller Pod w/ Gauges Sport Compact Auto & Import Performance Superstorehttp://www.glowshiftdirect.com/
Zeitronix Wideband 02 sensor- Road Race Engineering's 4G Eclipse Parts and Performance
Weight Reduction
Cf Hood- Auto City Imports : Sport Compact Auto & Import Performance Superstore
Cf Body Kit- Auto City Imports : Sport Compact Auto & Import Performance Superstore
Cf Engine Cover (or remove completely)- http://www.roadraceengineering.com/4g.htm
Cf Hatch- 2006+ Mitsubishi Eclipse VIS Carbon Fiber Trunk Lid Sport Compact Auto & Import Performance Superstore
A CAI, new headers, and the underdrive pulley by RRE will significantly help lower weight since our stock parts are a bit on the fat side
Aftermarket exhaust should lower weight as well (This could be dependent upon the manufacturer)
Rear Seat Delete (Can't remember where I seen this)
Remove Spare tire/tools
Lighter racing wheels- http://www.wheelsnext.com
Remove radio, speakers, and sub woofer (If you have it)
Remove Trunk cover
Sparco or other aftermarket steering wheel- www.autocityimports.com
Sparco Racing seats w/ Harness- www.autocityimports.com
Remove Rear Wiper Blade/Motor*
EVO X Small Battery Kit - http://www.amsperformance.com/cart/Mitsubishi-Lancer-Evolution-Evo-10-X-Ignition.html
Exhaust
Magnaflow 2.5" Cat-back- 2006+ Mitsubishi Eclipse (4Cyl) MagnaFlow Cat-back Exhaust Sport Compact Auto & Import Performance Superstore
RRE Axle Back- http://www.autocityimports.com//200...re-axleback-exhaust-system-p-8026.htmlhttp://www.roadraceengineering.com/4g.htm
WORKS Catback- 2006+ Mitsubishi Eclipse (4Cyl) WORKS Cat-Back Exhaust Sport Compact Auto & Import Performance Superstore
Drivetrain
TWM ShortShifter- 2006+ Mitsubishi Eclipse (4cyl) TWM Short Shifter Kit Sport Compact Auto & Import Performance Superstore
Clutch Masters Flywheel- 2006+ Mitsubishi Eclipse (4cyl 2.4L) Clutch Masters Aluminum Flywheel Sport Compact Auto & Import Performance Superstore
Spec Clutch Kit up to (1-5)- 2006+ Mitsubishi Eclipse Clutch Kits Sport Compact Auto & Import Performance Superstore
ClutchMasters clutch kit stage (1-4)- http://www.autocityimports.com//2006-eclipse-clutch-kits-c-54_1176_3025.html
Wavetrac Torsen Limited Slip Differential- Road Race Engineering's 4G Eclipse Parts and Performance
Energy Suspension Shifter Base Bushing- Road Race Engineering's 4G Eclipse Parts and Performance
WORKS Spin Flywheel*- http://store.worksmotorsports.com/Eclipse_4th_Gen_2006_s/207.htm
WORKS Clutch kit* (Stage 1 & 2)- http://store.worksmotorsports.com/Eclipse_4th_Gen_2006_s/207.htm
WORKS Shifter Cable Bushings*- http://store.worksmotorsports.com/Eclipse_4th_Gen_2006_s/207.htm
Forced Induction
RIPPMod Supercharger- (Must find used, no longer make them to my knowledge)
Custom Turbo Kit:
Cast t3/t4 turbo manifold* (Direct bolt on)- Ebay, Google, Forums
AEM Water/Alcohol Injection Kit- http://www.roadraceengineering.com/4g.htm
Nitrous- Check google, ebay, and forums
NOS
NX
ZEX
Visual
Eyelids (Ralliart, Projection, Vision styles) - http://www.autocityimports.com//2006-eclipse-lids-c-54_1176_2888.html
CF X Bumper Bar cover- http://www.autocityimports.com//2006-eclipse-lids-c-54_1176_2888.html
Sport Vent Window Covers- http://www.autocityimports.com//2006-eclipse-lids-c-54_1176_2888.html
CF X Exhaust Shield- http://www.autocityimports.com//2006-eclipse-lids-c-54_1176_2888.html
Lambo Door Kits- http://www.autocityimports.com//2006-eclipse-lambo-doors-c-54_1176_1184.html
Body Kits- http://www.autocityimports.com//2006-eclipse-body-kits-c-54_1176_1177.html http://www.atoycustoms.com/bodykits/mitsubishi/
Aero Body Kit*- http://mitsupartsworld.com/11-mistsubishi-eclipse-sport-aero-kit.html
CF and Wide body fenders- http://www.autocityimports.com//2006-eclipse-fenders-c-54_1176_2674.html
Halo Projection LED Headlights- http://www.autocityimports.com//2006-eclipse-headlights-c-54_1176_2887.html
LED Taillights- http://www.autocityimports.com//2006-eclipse-tail-lights-c-54_1176_2886.html
Halo LED Fog Lights- http://www.autocityimports.com//2006-eclipse-lamps-c-54_1176_1182.html
CF Dash Trim Kits- http://www.autocityimports.com//2006-eclipse-dash-kits-c-54_1176_1178.html
Wing/Spoilers- http://www.autocityimports.com//2006-eclipse-spoilers-c-54_1176_1208.html
Vinyl or CF Roof overlay- http://www.autocityimports.com//2006-eclipse-roof-vinyl-overlays-c-54_1176_3513.html
HKS Oil Filler Cap- http://www.autocityimports.com//hks-limited-edition-oil-filler-cap-mitsubishi-models-p-8831.html
Magnetic Car Bra*- http://www.autocityimports.com//2006-mitsubishi-eclipse-magnetic-car-bra-hood-mask-p-4905.html
WORKS Grab Shift Knob*- http://store.worksmotorsports.com/Eclipse_4th_Gen_2006_s/207.htm
Ichiba Hubcentric Wheel Spacers*- http://www.autocityimports.com//ichiba-hubcentric-wheel-spacers-version-ii-p-9279.html
Aluminum or CF wing*- www.autocityimports.com
LED light upgrades*- http://stores.ebay.ca/Quebec-Light-Source or ask member "Zedawg" on the forums here.
18mm Blue LED Cigarette lighter*- http://www.ebay.com/itm/18mm-BLUE-L...es&fits=Make:Mitsubishi|Model:Eclipse&vxp=mtr&hash=item53eb7bdb60#ht_3774wt_922
Mitsubishi Lancer Evolution MR Badge*- www.oemmitsubishiparts.com Part #: 7415A299
Cargo Organizer*- http://mitsupartsworld.com/20-mitsubishi-eclipse-cargo-organizer.html
Cargo Net*- http://mitsupartsworld.com/19-mitsubishi-eclipse-cargo-net.html
Cargo Cover*- http://mitsupartsworld.com/17-mitsubishi-eclipse-cargo-cover.html
Mitsu Weather Floor mats*- http://mitsupartsworld.com/13-mitsubishi-eclipse-all-weather-floor-mats.html
Mitsu Mud Flaps*- http://mitsupartsworld.com/27-mitsubishi-eclipse-mud-flaps.html
Mitsu Wind Deflector (Spyder)*- http://mitsupartsworld.com/26-mitsubishi-eclipse-spyder-wind-deflector.html
Eclipse License Plate Frame*- http://mitsupartsworld.com/22-mitsubishi-eclipse-license-plate-frame.html
Aluminum Eclipse Fuel door*- http://mitsupartsworld.com/12-mitsubishi-eclipse-fuel-door-alloy.html
Cargo Mat w/ and w/out sub*- http://mitsupartsworld.com/18-mitsubishi-eclipse-cargo-mat-subwoofer.html
Shifter boot, arm rest and e-brake boot*- http://www.redlinegoods.com/Eclipse06shiftboot.php
Ralliart Wheel Locks*- http://www.mitsupartsworld.com/lanc...d.com/lancer-sportback-exterior/281-mitsubishi-ralliart-fluted-wheel-locks.html
HIDS* - http://www.ddmtuning.com/
Remote Starter #MZ360271EX*- http://www.mitsubishipartscenter.co...dex.cfm?searchText=MZ360271EX&make=Mitsubishi&action=oePartSearch&siteid=216144
Aluminum Custom door sills*- http://www.carid.com/2006-mitsubish...html?utm_source=shopzilla_com&utm_medium=comparator&utm_campaign=Shopzilla_feed
Useful How To's/Threads
http://club4g.org/board/4g-eclipse-gs-se-specific/21527-swapped-throttle-body.html
http://club4g.org/board/4g-eclipse-gs-se-specific/24447-how-gs-oil-catch-can.html
http://club4g.org/board/performance/15593-4g69-rre-header-install.html
http://club4g.org/board/performance/9404-how-throttle-body-bypass-tutorial.html
http://club4g.org/board/performance/657-how-twm-short-shifter-install-gs-gt.html
http://club4g.org/board/suspension/868-how-eibach-pro-kit-spring-install.html
http://club4g.org/board/suspension/867-how-progress-24mm-sway-bar-install.html
http://club4g.org/board/suspension/.../suspension/3002-how-es-trailing-arm-rear-lower-control-arm-insert-install.html
http://club4g.org/board/electronics/12006-how-f-i-c-basics.html
http://club4g.org/board/performance/11592-how-installing-zex-82021-wet-kit.html
http://club4g.org/board/performance/11620-how-install-nx-20915-10-nitrous-kit.html
http://mitsupartsworld.com/attachment.php?id_attachment=7 - Aero Kit install*
http://club4g.org/board/show/27397-how-paint-factory-headlights.html#post673180 - how to paint stock headlights housings
http://club4g.org/board/performance/659-how-rre-under-drive-pulley-install-gs.html
http://club4g.org/board/4g-eclipse-gs-se-specific/23961-how-rre-underdrive-pulley-visual-how.html *
http://club4g.org/board/gs/18215-how-swap-injectors-4g69.html
http://club4g.org/board/performance/11394-another-how-cold-air-intake.html
http://club4g.org/board/4g-eclipse-gs-se-specific/18244-motor-mounts.html - How To Install on post #29
http://club4g.org/board/general-4g-eclipse/20261-how-install-harness-bar.html *
http://club4g.org/board/performance/27982-how-delete-intake-manifold-resonator-tb-spacer.html
http://club4g.org/board/performance/27872-how-install-oil-catch-can.html
http://club4g.org/board/4g-eclipse-...ific/29468-how-gut-catalytic-converters-4g69-stock-exhaust-manifold-header.html
http://club4g.org/board/4g-eclipse-...1-beginners-guide-modding-youre-2-4l-4cyl-gs-what-route-should-i-go-thread.html
http://club4g.org/board/eclipse-performance/4564-beginners-guide-modding.html
http://club4g.org/board/eclipse-per...eclipse-performance/22217-forum-fyi-upgrades-needed-fully-built-4g-eclipse.html <--One of my Favorites!
http://club4g.org/board/eclipse-performance/26190-index-very-best-performance-parts-threads.html
http://club4g.org/board/eclipse-per...e-performance/834-valuable-reading-novice-performance-enthusiasts-part-1-a.html
http://club4g.org/board/problem-reports/26902-guide-common-problems-concerns.html#post672470
http://club4g.org/board/eclipse-per...d/eclipse-performance/23127-150-diy-tuner-tips-direct-copy-paste-importsnc.html
http://club4g.org/board/eclipse-performance/7631-weight-reduction-numbers.html
http://tearstone.com/shop/2006-Eclipse-Factory-Service-Manual.html
Info on Turbo's and Superchargers
http://club4g.org/board/gs/27672-how-choose-right-turbo.html
Other
http://club4g.org/board/shine/16627-car-care-guide.html#post673646 <--This thread has NOTHING to do with performance, but is a great read and very informative for taking care of your beautiful piece of machinery.
http://club4g.org/board/4g-eclipse-gs-se-specific/20160-how-change-spark-plugs-gs.html
Credits to: Gser7, Akley88, Hellcat, Animefreak1983, 3cl1ps3, Mwaterous, tripplediamonds23, FreakyDeaky, xxkevinchuxx, LPfenix182, McClipseGT, Fearlezz, agustin, Mrgibs121, Tsensational, nokiauser, shortyboy192, Zedawg and Daxenth for helping add more to this list! Thanks guys!
Items marked with an asterisk (*) are items that other members helped add to this list!
Updated 02/13/12
#15 ·
dont forget aluminum wings
lol no but if im not mistaken., the fuel rails and injectors (<dont hold me to that) will fit on our cars
#28 ·
Hehe :wub: you didn't say no :ghey: Dax :naughty: haha j.p
Didn't want you guys to go unnoticed on this and take all the credit. I'll actually use a "*" to mark what was added by other members!
You guys did a fantastic job writing this up! Good work all the way around the engine stuff is golden. Their isn't anything you can really "add" to forced induction accept that bolt on manifold sense that's the only mass produced part :(. Hopefully soon that will change.. I would rep you guys but my phone won't let me
Thanks man, just trying to help the community :) :bigthumb:
#27 · (Edited)
Edit: one thin you could add is a link to the blueprint of the cutout to install the stiffy
#31 ·
i e repd him hard... right in the throat. he begged me to stop but i just kept giving it to him.
kinda like my actual sex life. good for about 3 sec and then im all out for a few days...
#33 ·
#36 ·
Will add all of this man and credit you! Big thanks!!! :bigthumb:
Too bad Ripp Mods doesn't make the 4G69 headers anymore otherwise, you could put that too on the list.
Under the "Weight Reduction" section, you have "RRE or OBX Headers" and "the RRE Underdrive Pulley" but I'm guessing that's a typo.
You could put in the intake manifold for the prev generation Lancer Ralliart. It's more or less PnP.
It's time to e-Rape your ass! #nohomo
Haha I thought it felt a bit sore :squint: lol, I'll add the intake manifold, and I put the pulley and headers under that section also because they do both weigh less then the originals thus "reducing the weight" some. The headers drastically weigh less due to no catalytic converters. Also a CAI weighs less then the stock airbox. Not necessarily specific for weight reduction but wanting to give people an idea of what does effect our heavy ass cars weight lol. I'm going to reword it to make more sense now haha. Thanks tho :woohoo:
#35 ·
#42 ·
